Looking for CV carb info
Old Nov 26, 2009 | 08:37 PM
Squidley's Avatar
Squidley
Default Looking for CV carb info
Hey All,
I have been searching on the forums for the past couple of days about info on doing an eventual carb swap. The bike is a '79 FLH Electra Glide with an 80 cube motor. I dont believe that there had been any serious engine modifications to the bike, as the PO wanted to keep it extremely driveable. Right now it has what I believe to be a Bendix/Zenith carb on it? (sorry not familiar with the different carbs) It runs, but the carb is in rough shape and I have been reading about the CV's reliability and maintenance free aspect. My questions are this....
What size carb should I be looking for on an 80 cube with no real engine mods? I have been hearing a few #'s from 38mm to 45mm and 42 seems to keep coming up.
I know there are Mikuni guys here and H/D CV guys, both seem like good carbs. Which one will be the easiest and least expensive to change over?
I'm also assuming that I will have to change out throttle cables and choke cable to accept the newer style carb.
Any and all comments are welcomed as I have a lot to learn on this bike. My advanced apologies if this is in the wrong forum area...Thanks for your time.
Old Nov 26, 2009 | 08:43 PM
MJ's Avatar
MJ
Hello Friend! I bet if you post this in the evo section, you will get some good help. Alot of good wrenches there willing to help.
Good Luck!
Old Nov 26, 2009 | 08:46 PM
Squidley's Avatar
Squidley
Thanks for the heads up
Old Nov 26, 2009 | 10:41 PM
hatchetman's Avatar
hatchetman
A 40 or 42 mm CV carb will work well on your 80 CI. I have a Mukuni which replaced my Keihn carb & there is a big difference! You dont have to do engine mods for this carb but you do need the manifold, the throttle cables & the air filter to go with your new carb.
Old Nov 27, 2009 | 06:44 AM
miacycles's Avatar
miacycles
We have a permanent adaptor that mounts on the carb and turns it into a bolt-on carb so that you do not have to change the manifold. It is really popular with the shovel head crowd!!
Old Nov 27, 2009 | 08:28 AM
hatchetman's Avatar
hatchetman
Where do you get those adapters & how much???
Old Nov 27, 2009 | 10:24 PM
miacycles's Avatar
miacycles
We have them made and they sell for $35 plus shipping
Old Nov 29, 2009 | 09:42 AM
Squidley's Avatar
Squidley
Shameless Bump back up top
BTW I have seen a lot of the CV and Mukuni carbs on ebay with the part #'s on them. Does the # distinguish what CC's the carb is and if so what would I look for to determine that?...Thanks again for all the help.
Old Nov 30, 2009 | 04:54 PM
t150vej's Avatar
t150vej
No. There are simply part numbers... avoid 88 Sportster CVs because they have no accelerator pump - you can tell by looking at a photo.
Good luck on your swap and do let us know how you like it when you're done
Old Nov 30, 2009 | 05:48 PM
sqdealgeorge's Avatar
sqdealgeorge
If the bike runs good with the Bendix/Zenith leave it as is That was a good carb
