Base Gasket Leak
Old Dec 18, 2009 | 09:20 PM
I8SMK4U's Avatar
I8SMK4U
Default Base Gasket Leak
How long can you let a base gasket leak go on. Yea its a PITA but cash flow is a little low. Its been leaking from the rear of the rear cylinder. At idle you can see it bubble. Leaking like that for about a year, 9,000 miles of riding.
Old Dec 18, 2009 | 10:08 PM
stevelonewolf's Avatar
stevelonewolf
That's one way to change the oil. That could depend on how bad it's coming out. Most of those gaskets are fibre/paper w/ a bead. Can't see it being a TC unless the o-ring is shot.
Old Dec 18, 2009 | 10:12 PM
gsxrboy96's Avatar
gsxrboy96
you can let it leak like that as long as you keep oil in it, personally, even if funds are low, id buy a cometic gasket kit 60 bux, and a manual. 30 bux and do it. besides a torque wrench, no special tools are needed and its very straighfoward. chad.
Old Dec 18, 2009 | 11:34 PM
stevelonewolf
I find it a little tuff with out a ring compressor.
Old Dec 19, 2009 | 12:09 AM
I8SMK4U's Avatar
I8SMK4U
I found a Top End gasket kit from Cometic in Drag Spec. When I get her apart, what other bolt on's should I consider to get that "reliable" power. Emphasis on reliable, plan on doing Sturgis from SoCal. Or should I keep her as she was?
Old Dec 19, 2009 | 12:16 AM
stevelonewolf
Well you'll have the heads off....Consider head work. Check your rocker arms,shafts,valve stems,seats,collars,springs. Freshen up your cylinders,rings.
Old Dec 19, 2009 | 04:57 AM
gsxrboy96's Avatar
gsxrboy96
the only thing i would do is maybe a ev27 camshaft, and rering the bike, also as far as a ring compressor, i found it actually more difficult to use a compressor around all the cylinder studs, so i have my pops come over, and i feed the rings in by hand, 100% percent success rate so far.
Old Dec 19, 2009 | 06:46 AM
hotrod351's Avatar
hotrod351
first leave the piston in the barrel, you can lift the barrel up enough to pop the clip and pull the pin. thats how i put mine back together, piston installed in the barrel and didnt nee a ring compressor just small screw driver. after all thats how they use to, and maybbe still , install the porsche 911 barrels, with the pistons installed in them then line up the pin. it really pretty easy to do. i had to heli-coil a front head bolt on mine. i know next time to coat the base gasket with permatix ultra grey, i dont care what any body says about not using it i know it works and havent found any one that had any problems after doing it that way.
Old Dec 19, 2009 | 06:49 AM
lionsm13's Avatar
lionsm13
I cleaned mine up and used some pourable silicone and it seems to have stopped it. That was over 2 years ago. There's a thread about some where on this site. That's where I got the idea. Cheap fix and it worked for me.
Old Dec 19, 2009 | 07:24 AM
hotrod351's Avatar
hotrod351
thats what i did on my front cylinder after i heli coiled one front head bolt, i used a permatix weather strip adhesive, it came in a really small tube and was really runny but it worked.
