replacing intake manifold seals
Old Dec 19, 2009 | 07:28 AM
hotrod351's Avatar
hotrod351
Default replacing intake manifold seals
well ive been meaning to replace my intake manifold seals for quite some time, do they leak, hell i dont know, but ive take the manifold off twice now and the last time it didnt look so good. any way i have the new seals, for a S&S shorty, and wondered if i should coat the seals with something. i have some oring lube, dow 101, or just install them and call it good.
Old Dec 19, 2009 | 08:33 AM
miacycles's Avatar
miacycles
We put them in dry, however there are people that use various lubes.
Old Dec 19, 2009 | 09:11 AM
stevelonewolf's Avatar
stevelonewolf
I always use vaseline. They have the ability to fold over when sliding in place and will seat better with a lube.
Old Dec 19, 2009 | 01:54 PM
hotrod351's Avatar
hotrod351
ok i installed the new seals, applied some lube, question is how loose is the manifold suppose to be. i mean with it tighten down i can rotate it up and down. couldnt hardly do that with the old seals but then there were hard. i bought the rubber seals from jp cycles for a S&S manifold.
Old Dec 19, 2009 | 03:34 PM
miacycles's Avatar
miacycles
it shouldn't move that much, however the aircleaner will hold it in place so don't worry.
Old Dec 19, 2009 | 06:03 PM
stevelonewolf
It's gonna move. You are compressing rubber. As long as the 4 bolts are tightn you're fine.
Old Dec 19, 2009 | 06:08 PM
stevelonewolf
The S&S intake seals are smaller than the standard size. I think it has to do with their heads.
Old Dec 19, 2009 | 08:24 PM
hotrod351's Avatar
hotrod351
that was the problem, the S&S seals are a lot smaller. but with it tight i could lift the carb and intake up and it would fall on its own. anyway i called J&P and the guy, jake, checked the S&S against OEM and right away he saw the OEM were bigger so he sent me a OEM set, free of charge. nice to know they stand behind there product. i put the old one back on for now, gotta ride, and i really think there fine, just bored.
Old Dec 19, 2009 | 09:50 PM
stevelonewolf
Right on. Good to hear that with JP..
Old Dec 24, 2009 | 06:25 AM
t150vej's Avatar
t150vej
With "normal" (oem type) seals, they shouldn't rotate easily at all with the bolts tightened to snug. That's why it's a pain to get the air cleaner mounts, grommet seal and manifold all lined up with new ones. I generally mark the manifold before teardown to make that part of it all quicker.
I've sorta trashed James gaskets lately but try theirs for your manifold if the OEM types still lets the mainfold wiggle bad up and down. I don't have a photo, but unless they have changed lately, they have a groove that the manifold ends fit into that will take up a lot of extra clearance between the inlet and head. Like the regular tapered o-rings but come all the way around to the head surface with a flat. Almost like the grommet for the carb in a way...
