EV27 cam
Old Jan 18, 2010 | 03:24 AM
Brettfullthrottle's Avatar
Brettfullthrottle
Originally Posted by gsxrboy96
Yes, going from a stock stick to a ev27 or something similar should show mpg improvements.
My mileage DROPPED when going to the EV27! Even when I take it easy on the freeway it has dropped considerably.
The power,however,is a completely different story! She runs much better with the Andrews cam!
Old Jan 18, 2010 | 03:27 AM
Brettfullthrottle
Originally Posted by I8SMK4U
With those Horses and Torque, What are you guys doing for your clutches?
I am running the stock clutch....no problems!
Old Jan 18, 2010 | 07:05 AM
pajoe's Avatar
pajoe
I agree with Brettfullthrottle:
I had no problems with the stock clutch using the ev27, 10:1 pistons, head work etc. etc.
However, if you are concerned, I have had good luck with the Energy One products . The BT-11 kit without the heavier spring is $93.95 and stronger than stock.
http://www.energyoneclutches.com/pro...&cat=15&page=1
I am currently using the BTX-11 1990-97 Big-Twin & 1991 to Present Sportster (XL) - Extra Plate Kit w/spring that retails for $106.00 with my 113" engine. The heavier spring makes it a little harder to pull the clutch.
Saturday was our first ride of the year, it was nice to get out again. There was a little more salt,water and gravel on the roads we ride on than I like but overall a great way to spend a few hours on a sunny afternoon with temperatures in the 50's.
http://www.youtube.com/watch?v=-lMpR0RBYR0
Old Jan 18, 2010 | 07:12 AM
miacycles's Avatar
miacycles
You should be in the mid 40's to 50 with that setup. Sounds like you are running rich, this could "wash" the rings. Check your plugs. What's been done to the Carb??? What do you have for gearing ??
Old Jan 18, 2010 | 08:09 AM
gsxrboy96's Avatar
gsxrboy96
If you retained your stock cv but rejetted it correctly, your mileage should have went up, thats been my experience.
Old Jan 18, 2010 | 08:41 AM
HGM's Avatar
HGM
I'm getting 45-50mpg with the bigger SE 11 cam, 9.5:1 pistons and headwork.. I'd check your plugs real closely, I agree that it sounds like your running too rich..
Old Jan 18, 2010 | 08:42 AM
2nd Mike's Avatar
2nd Mike
I have a similar set-up with efi and average 40+ on the highway.
I could probably do better but can't seem to stay out of the gas!
Old Jan 18, 2010 | 09:36 AM
legacycycles's Avatar
legacycycles
Oops
With my dresser,2up highway riding i get low 40's.In town low to mid 30's.At its a 10.5:1with an ev 51 with s/s super e carb.Id have to agree with the majority on this and say,check youre jets and plugs,maybe even see about having it tuned.Carb tuning is usally affordable,I only charge about 100.00 for tuning a carb bike....By the way im making mid 80's hp and tq,still running stock clutch.
Old Jan 18, 2010 | 01:17 PM
Brettfullthrottle
I have stock gearing. I have had this dyno tuned.....not sure what is going on. She burns oil however....about a quart every 1200 miles. Could this be part of the problem?
On the freeway I tend to keep her at 75 to 80. guess that's not really "taking it easy".Maybe the problem is my wrist!
Old Jan 18, 2010 | 01:34 PM
HGM's Avatar
HGM
I'm never below 80 on the highway and thats probably 75% of my riding... I'd be concerned if I got less than 45mpg, but again, we dont have the same exact setup.. Sounds like your engine may be tired, but I'm not the pro that some of these other guys are..
