Has anyone changed sprockets in the primary?
Old Feb 7, 2010 | 11:18 AM
phat96's Avatar
phat96
Default Has anyone changed sprockets in the primary?
Hi guys, has anyone changed there sprocket? say to a 22 tooth sprocket, I was told my throttle response would be greatly improved?
Thanks
Old Feb 7, 2010 | 11:54 AM
gsxrboy96's Avatar
gsxrboy96
Hey, i havent changed a sprocket personally, But i have a screamin eagle primary chain drive for the touring bike i bought, but never used, it changes it to a 1.7 ratio primary, whatever that means??? Id sell it cheap if thats the route you decide to take. chad.
Old Feb 7, 2010 | 11:57 AM
dc1450's Avatar
dc1450
Yea, it was common practice with side car models. It will increase throttle response but you will be turning about 4000 RPM at 70MPH.
Old Feb 7, 2010 | 12:08 PM
1997bagger's Avatar
1997bagger
I changed to 3.37 by changing both sprockets, the 22 front should be close to the same gearing. Don,t have to ride the clutch taking off, 55 mph throttle roll on is alot sharper and cuts down on down shifting and no negatives, I did catch myself sometimes pulling up for another gear at the beginning when cruising but that feeling goes away.
I read there is a trick of turning the adjuster upside down to remove the chain slack from the 2 teeth change but maybe somebody can go into detail.
Old Feb 7, 2010 | 01:23 PM
Moog Player's Avatar
Moog Player
You can modify the tensioner or you can get a chain that is a link or two shorter. The chain is not expensive.
Old Feb 7, 2010 | 04:55 PM
phat96's Avatar
phat96
97 bagger, my Indy said the same thing about the 22 tooth one, almost the same gearing,
(turns out it was the 23 tooth sprocket not the 22 has the same gearing, he said 3000 rpm on the 23 toother at 70 miles an hour is what I can expect. Stock is 25 teeth on the sprocket.)
DC as far as 4000rpm at 70 he said that happens on a 21 tooth sprocket.
gsxr thanks anyway but I'm going to go ahead and do the sproket tomorrow and I'll post the results next week.
Not an expensive modification and he said I could wait and he'd be done in an hour, that was a first.
Mark Williams
21
Aug 31, 2018 11:42 PM
stephtell
EVO
Apr 20, 2016 06:28 PM
neverdown
Jun 17, 2012 05:47 PM
WRAITH
Oct 18, 2010 11:48 AM
Velocity1
Mar 6, 2008 01:44 PM
