help w/speedometer cable/drive unit
Old Feb 7, 2010 | 12:56 PM
roach's Avatar
roach
Default help w/speedometer cable/drive unit
Hi all I need some help. I'm in the process of putting a bat wing fairing on my '90 FLHS. I need to change the speedometer cable. I don't know how to disconnect the speedo cable from the speedo drive unit so that I can remove the cable from the front fender. I have looked in the service manual and the parts book and haven't found a discripition.
Thanks,
Roach
Old Feb 7, 2010 | 01:02 PM
xxxflhrci's Avatar
xxxflhrci
If I remember correctly, it just screws on.
Old Feb 7, 2010 | 01:25 PM
Beemervet's Avatar
Beemervet
Disconnect from the speedo then it will unscrew from the drive, it will be obvious once you start.
Old Feb 7, 2010 | 01:38 PM
roach's Avatar
roach
Thanks, I will give that a try
Roach
Old Feb 7, 2010 | 02:12 PM
roach's Avatar
roach
Man! That B***H was tight. The end is splined rather than threaded. Does that mean that it should push together rather than screw? There is a very small set screw that I removed before attempting the removal.
Roach
Captain Jack 99
Dec 22, 2019 11:46 PM
johnod
EVO
11
Sep 15, 2014 08:52 PM
volorng
General Topics/Tech Tips
Mar 28, 2012 11:57 PM
JustDave71
Jan 19, 2010 04:57 PM
Rynb15
Jan 23, 2009 08:32 PM
