MM Conversion - Pingel
Old Feb 28, 2010 | 10:40 AM
1997bagger's Avatar
1997bagger
Default MM Conversion - Pingel
Has anyone figured out a way to get around the Pingel shutoff valve on the MM To carb conversion? Seems like everyone buys the valve but frowns on the price and advertised "the only valve that fits the adapter"
Old Feb 28, 2010 | 12:02 PM
Moog Player's Avatar
Moog Player
Make your own adaptor. All you need is a lathe. Everyone has one of those, don't they? (I do, so I get to be an ***.) I used the Pingel kit. The stock HD vacuum petcock is supposed to screw into it. I haven't done the conversion yet, waiting for riding season to be over and a free weekend to do it.
Old Feb 28, 2010 | 12:48 PM
1997bagger's Avatar
1997bagger
OK, I still have a box of winter saved back for you and you might need that lathe to build a snow shovel
Yea, I will probaly drive myself crazy trying to find a budget system and end up buying the Pingel valve, the only thing I can see is the Pingel adapter is necked down and only accept the smaller Pingel filter, I'll need to get the adapter and see how much thickness is in the pass thru, think about it for a while and weigh in the " if I screw it up" and buy the Pingel.
Old Feb 28, 2010 | 01:27 PM
Moog Player
What dimension do you need, I have the adaptors in a bag out in the shop. I haven't even opened the package, yet. I haven't picked up the petcock, enrichener or the throttle cables yet.
Old Feb 28, 2010 | 01:49 PM
1997bagger's Avatar
1997bagger
On the adapter from tank to fuel valve, see if the flow hole where the valve filter slides thru can be opened up for a larger filter used on other fuel valves. It might be sized only for the smaller Pingel filter and can be opened up.
Old Feb 28, 2010 | 05:05 PM
Moog Player
No, there is no way to open it up anymore. You could use a petcock without an in tank strainer and put a real filter in line.
Old Feb 28, 2010 | 06:28 PM
1997bagger's Avatar
1997bagger
Thanks for the info and help, points me in a direction
GraemeR
Blowers/Turbos/Nitrous Oxide
Dec 23, 2024 05:48 PM
wtsamatta
Nov 22, 2016 08:45 PM
Z
Exhaust System Topics
Mar 9, 2014 07:45 PM
ryamatt
Aug 24, 2011 07:53 PM
Storm 4 U
Oct 22, 2007 07:37 PM
