cam question
Old Mar 19, 2010 | 01:10 AM
hog-doc's Avatar
hog-doc
Originally Posted by 09DynaMan
Not one comment of a mechanical nature.
Just abuse.
Which makes sense.
I do not abuse you, and I outline the correct procedure.
You abuse me, and post only misconceptions.
This makes you all great guys, right???????????????
You have strange ideas.
But you may relax, I will continue to post the truth, and stick to the mechanical side.
Buddy must have changed his mind.
Iam not sure where you learned how to install a cam in an Evo BUT buddy is correct in removing both lifter blocks and checking end play with feeler gauges, been the factory proceedure since, oh, 1936! Iam pretty sure Harley could afford dial indicators even back then.
.010"-.015" is where I like to set them. The other part of having the lifter blocks out is so you can check gear lash, with the seal removed from the cam cover, and this is done by feel, if you know what your doing. Not something you can do with the blocks installed since you need to slip your fingers down to the cam gear through the lifter block bores!
Old Mar 19, 2010 | 08:46 AM
rodente's Avatar
rodente
Hey HogDoc....
Speaking of gear lash, I have just installed a new cam into my bike, set my end play to .011", new Torrington inner, lifters, push rods etc.... I did as you just said and checked my cam gear lash while lifter blocks were out, as that seemed to be the only way(IMHO) to get at the cam gear with cover installed. My question is......why so LITTLE gear lash on the cam gear???? I realize that the gear is not gonna expand much.....but if I recall the spec is .000"-.0015"......thats tight......lol. Just wondering if you could shed some light, to me it seems tight....I have been building diesels in heavy equipment for quite awhile and have never seen anything calling for "0" tolerance.....but then again, this is the first time into a Harley, and I have found that they have ALL their own little rules and such......LOL. Have a good day everyone!!!!
Old Mar 19, 2010 | 09:12 AM
hog-doc's Avatar
hog-doc
If the gear lash is looser than the spec you will get gear clatter which comes from the spring pressure loading the gear lobe back and forth as the lifter rolls over the nose of the cam. Obviously tighter than spec will produce a whine from the gears.
Old Mar 19, 2010 | 03:32 PM
09DynaMan's Avatar
09DynaMan
It is 2010.
You do not have to remove lifter blocks.
Why can you not understand that?
It is so simple.
KEEP UP TO DATE.
Now, according to your post, you have to use the, what you call, 1936 HD method for cam end play check.
But then you use a "know what you are doing by feel" gear lash method.
I hope this helps you see how ridiculously hypocritical you are being.
Old Mar 19, 2010 | 04:02 PM
hog-doc's Avatar
hog-doc
It is 2010.
It is so simple.
KEEP UP TO DATE.
You have never changed an Evo cam have you?
WTF does what year it is now have to do with the proceedure that has been used for decades. Your right you DO NOT have to remove the blocks to CHANGE the cam, but you DO have to remove them to set it up properly, if you'd ever done this job you would know that.
Evos have been out of production for 11 years, nobody is developing NEW set up and install proceedures for them. Tried and trued methods son! Go ask any REAL HD mechanic, dealer or indy, how to set up a cam, then get back to us, OK sunshine!
Old Mar 19, 2010 | 09:06 PM
HGM's Avatar
HGM
Originally Posted by rodente
Hey HogDoc....
I recently went through it myself.. Hog Doc answered the question right with the discription of spring pressure causing a rocking.. I'd like to add one thing though.. If you look in your manual, under cam installation, you'll see reference to "pins".. These pins are set between the teeth in order for you to get an accurate measurement of the gears.. The goal is basicly "0" backlash, but I didnt see it actually called out.. Its the only way to accuratly measure it.. The "feel" method above is the next best choice I suppose, but not accurate by any means, just gets you close.. If too tight, you'll get a whine. If too loose, you'll get a "tick"..
Old Mar 19, 2010 | 09:13 PM
hog-doc's Avatar
hog-doc
You use the pins to measure your gears once you establish loose or tight fit by feel. Once you have the diameter of your gears then you refer to the chart to figure what gear to select to fix the loose or tight fit!
Old Mar 20, 2010 | 05:53 AM
09DynaMan's Avatar
09DynaMan
Wrong again.
You do not use the pins after "feel".
That is rubbish.
After decades of professional wrenching, it never ceases to amaze me how some folk can get it so wrong, AND THEN TRY TO GIVE ADVICE.
You do not need to remove the lifter blocks to set the end play, and .010 is not tight.
I have changed many.
I will not be calling you any names or pretending that I know anything about you.
Thats another difference between us.
STAY AWAY FROM MY LAWNMOWER.
Old Mar 20, 2010 | 08:05 AM
HGM's Avatar
HGM
Wrong again.
That is rubbish.
DUDE!! You know, you dont have to call people names to be a dick.. Everyone's got a different way of doing things and just because its not the way you do it, doesnt make them wrong.. Do you "need" to remove the lifters to check end play, no.. Can you remove them and check it that way if it makes you feel that you've done a better job?? Sure, why not.. Can you get close by feel?? I suppose, if you have several gears to try.. I just used the pins and it worked out fine for me.. To come out and purposly slam people's way of doing things is purely argumentative and pointless.. You would get much more respect if you would simply state the way you would do things and not slam others.. Just a tip... Right now, your comments are alienating you and causing people to totally disregard your input all together..
Old Mar 20, 2010 | 08:58 AM
prodrag1320's Avatar
prodrag1320
be glad your not asking about british stuff,or he`d REALLY come un-glued!!!
