Crazy Front End Shake!
Old Mar 17, 2010 | 05:44 PM
catchaclue's Avatar
catchaclue
1st Gear
Default Crazy Front End Shake!
I have a rediculous front end shake at 45 mph on my new to me 91 fxsts. I checked frontend for tight hardware (everything was tight). Neck bearings seem ok no slop or noise when rocking the bike with front brake applied. Front tire has lots of tread but shows some cracking due to age Im sure. Maybe its a wheel balance issue but it comes and goes very quickly so Im not confident of that. Think I might put new rubber on it and see what happens. Any advise from you old time springer guys have would be very welcome.
Brandon
Old Mar 17, 2010 | 10:45 PM
hatchetman's Avatar
hatchetman
Jack up your bike so the front tire is off the ground. Slowly turn the handle bars left to right. as you cross the strait ahead point, do you feel a little click? if you do, you have flat spots on your neck bearings.
Next, grab your front forks with front tire off the ground. push/pull & feel for movement in your neck bearings. They might be too loose!
Next, with rear tire off the ground. Push & pull sideways on your swing arm. you are looking for free play, you want none here!
Next, measure from center of rear axle on both sides to center of swing arm cap's. the measurement should be the same!
Look for abnormalities in the tread wear of your front tire & finally, check your suspension for leaks etc, how much fork travel do you have in the front?
Keep us posted!
hatch.
Old Mar 18, 2010 | 07:07 AM
I8SMK4U's Avatar
I8SMK4U
Are all your spokes tight?
Old Mar 18, 2010 | 07:22 AM
jaqmes's Avatar
jaqmes
follow hatchetman's advice first, but if the shake come out above 45 it's a question of balance. a tire with cracks? you got to change that just for safty reasons.
Old Mar 19, 2010 | 01:21 AM
hog-doc's Avatar
hog-doc
Follow hatchetmans advise AND check the rockers, they are most likely quite loose as they are the least serviced part on a springer. There is a very specific adjustment proceedure for them that requires a Torqu-o-meter or beam type torque wrench.
Old Mar 19, 2010 | 09:09 AM
catchaclue's Avatar
catchaclue
1st Gear
thanks for all the advise. put new rubber on it yesterday and still has the shake but interestingly shake comes in around 50 now lol. Put bike on lift, neck bearings seem tight and dont feel any clicks or binding while turning frontend. no slop whatsoever in swingarm. when i get home tonight i'll check the rockers as im starting to believe it is a springer issue. i have a factory manual now and it doesnt show an adjustment for the rockers just a torque spec but it does show bearings and races in there so im thinking i may need to replace a few parts. thanks again for the help
Old Mar 28, 2010 | 07:52 AM
chipdavey's Avatar
chipdavey
I had an upper speed "wobble" on my springer some time ago, and it turned to be the rear wheel spokes. Some were a bit loose. Had local indy true up spokes, havent had a problem since.
Old Mar 28, 2010 | 02:17 PM
bagga's Avatar
bagga
i would check for loose rear spokes.....if you have them.
Old Mar 28, 2010 | 02:22 PM
FLYING's Avatar
FLYING
Change the tire before you go and do anything else as it is already check cracked and if the new tire has a painted dot on it be sure it goes at the valve stem.
Old Mar 28, 2010 | 02:25 PM
knuck36's Avatar
knuck36
had same problem on a 1980 superglide, it was the rear spokes
