wheel rubbing on fender
Old Mar 20, 2010 | 01:32 PM
gnafin's Avatar
gnafin
Originally Posted by miacycles
If it's rubbing onyly on one spot and not the whole way around then it's probably a bent wheel or the tire isn't seated correctly or broken cords. That is if everything else is as it should be.
.wysiwyg { BACKGROUND: #ffffff; FONT: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; COLOR: #000000 } P { MARGIN: 0px } .inlineimg { VERTICAL-ALIGN: middle } well i think i might have had the spacer in the wrong way....does side A or B go to the bearing?
Old Mar 20, 2010 | 02:52 PM
gnafin's Avatar
gnafin
well i turned that spacer so it goes into the bearing... but was still hitting... but not as bad....so i put on my old wheel...and it is ok... does not hit...but it does have a dent to it...so i am thinking... am i missing some of the shims that go inside by the bearing? Hmm or could it be the tire size... they both are the same make and size but the newer one has a white-wall...
Old Mar 20, 2010 | 11:27 PM
BB4xl's Avatar
BB4xl
Are the spacers the right ones? A lot can happen since 84.
Old Mar 21, 2010 | 01:36 PM
gnafin's Avatar
gnafin
well i check the tire width and they are the same.... so i am thinking i am missing something in the bearing stack...like i said i got this wheel used and it had the bearings in it.....time to take them out and see what is going on...
Old Mar 21, 2010 | 08:01 PM
miacycles's Avatar
miacycles
Get the front wheel off of the ground and spin it, then look for a "wobble". If the bearing stack was off it should rub all the way around, not just in one spot.
Old Mar 24, 2010 | 10:36 PM
gnafin's Avatar
gnafin
well i dont have a wobble with my new wheel... and this one rubs...most of it...like i said i did put on my old wheel and it is ok....when i get home(i am a field service tech) this weekend i am going to pull the bearings.....any tricks? it sucks as i just have one day a week to work on my bikes....
Old Mar 31, 2010 | 09:11 PM
gnafin's Avatar
gnafin
well i pulled the old bearings and it did not have the shims in the right place. so i put in new bearings and race... got the shims in the right place... got the end play at .005....and well it still rubs but just a little....one thing... the fender i put on was used and had a dent in the front... so it could be bent(fender) i am going to try my new one this friday.....should be good....
Old Mar 31, 2010 | 10:02 PM
flashprez's Avatar
flashprez
Stupid question, but do you have the spacers on the correct side? There is a difference in width, which could throw the wheel off just enough to rub.
Old Mar 31, 2010 | 10:26 PM
gnafin's Avatar
gnafin
ya they are...thing is i have a used old fender with a dent on the front...and the new tire has a white wall, the old did not... but i am going to try the new fender...see how that is...
Old Apr 2, 2010 | 05:34 PM
gnafin's Avatar
gnafin
well i put on my new fender and....... yep it worked... it is ok....thanks for the help guys..
