oil coming out timing plug
Old Mar 18, 2010 | 08:15 AM
jimmie d wad's Avatar
jimmie d wad
Default oil coming out timing plug
heres my issue.i built a bike bought a motor that the rings had frose.rebuilt motor.finally got bike done.now its pushing oil past the timing plug.my question is why?do i have a oil line switched around,is the timing wrong on the breather gear,or some other issue?the motor is a 95 harley evo
Old Mar 18, 2010 | 08:38 AM
Dr.Hess's Avatar
Dr.Hess
Assuming your breathing system is OK, you could just need a bit of teflon tape on the plug.
Old Mar 18, 2010 | 09:04 AM
t150vej's Avatar
t150vej
If it's leaking out there running but not pushing oil out the breathers to the air cleaner, it's likely the plug or debris under it. If it blows out when the plug is removed for setting the timing, that's normal.
You can buy a new timing plug for about 3.00 if that one is compromised and whatever you do, don't overtighten! Part# 720
Old Mar 18, 2010 | 10:17 AM
jimmie d wad
ive tried teflon tape,an o ring,a plastic washer like on the drain plug of a car.couple weeks ago i put copper silicon on there.before i put the silicon i tightened it up just a bit too much.still some threads left but not all of them.there is no oil coming out of the head breathers.
Old Mar 18, 2010 | 06:58 PM
hatchetman's Avatar
hatchetman
Do you have good oil pressure reading? How well does the bike run & how much oil are you seeing coming out that plug?
Old Mar 19, 2010 | 07:33 PM
jimmie d wad
i dont have a pressure gauge.the valve train sounds like its getting oil.theres enough oil coming out of that plug that after 100 miles it'll leave a good strip where its running off my frame
barrywilson
Oil Archive (no new posts)
Nov 23, 2014 03:58 PM
Gra490
EVO
Dec 13, 2013 10:29 AM
jamala00
Mar 24, 2012 03:10 PM
Tonefiend
Sep 26, 2010 09:04 AM
harleydom55
Aug 11, 2008 05:09 PM
