Help! '87 turns over but wont fire
Old Mar 25, 2010 | 03:29 PM
ffjoey's Avatar
ffjoey
2nd Gear
Default Help! '87 turns over but wont fire
Hello everyone. I have an '87 Softail that I am having trouble with. Everything was going well, then one morning after it ran fine the previous day it would turn over and backfire every few times but would not start. Finally it did start but I had to keep the revs up to keep it running. After about 7 miles of trying to get home it died at a red light and refused to start again. Just turn over and over but no fire. I looked in the carb and it is getting fuel. I replaced the stock ignition with a Dyna S. Picked it up from the shop rode home and now it turns over and wont start again. I called the shop and they said my ignition switch on the dash is bad. Does this sound right? Something sounds off about it to me.
Old Mar 25, 2010 | 04:01 PM
Dr.Hess's Avatar
Dr.Hess
No spark? Could be an ignition switch, but that's a pretty simple check and should have been caught by the shop when they put the new ignition in and is usually not thermally related. Did they replace the pickup in the cone? Also, I think the 87 was a solid mounted motor, but the wire between the cone and the frame on rubber mount bikes tends to break inside the insulation and give those symptons. Regardless, if it isn't running, it's easy to diagnose. If it is running fine now, and only does it sometimes, that's a whole lot harder.
Old Mar 25, 2010 | 04:37 PM
t150vej's Avatar
t150vej
Could be the switch, but with the backfire and having to keep up the revs and now it's dead... I'd say it's a bad coil. And it may even ohm out good and still be bad... or was it replaced with the Dyna S conversion?
Old Mar 25, 2010 | 06:29 PM
sqdealgeorge's Avatar
sqdealgeorge
Just have to add this Dyna S is a great system All Dyna systems 2000 /2000i are great
Old Mar 25, 2010 | 11:38 PM
ffjoey's Avatar
ffjoey
2nd Gear
The coil was not replaced and that was the problem. Not sure why it was not replaced like I ASKED them to do but it is fixed now. Thank you all
Old Apr 5, 2010 | 06:53 AM
M&D88FXSTC's Avatar
M&D88FXSTC
1st thing Id do is check the plugs. once a bike plug fouls its pretty much done. I left the choke on lil too long (learning curve lol) on my 88 softtail & it did same thing. new plugs & problem solved. be worth a check....cheap fix
Old Apr 9, 2010 | 11:58 PM
just black's Avatar
just black
1st Gear
try disconnect battery, pull plugs and bring to TDC. reconnect battery,put plugs back in and try to start. should reset the module. you may not be firing at right time. This happened to me when monkeying around. need more info ask cause its to late to type much- good luck
Old Apr 10, 2010 | 12:43 PM
ffjoey's Avatar
ffjoey
2nd Gear
As earlier stated it was a bad coil. Many thanks for the input but she is running great now.
Kees
Shovelhead
Dec 8, 2015 04:32 PM
LQQK_OUT
EVO
May 28, 2015 03:31 AM
crawfordcl
Sep 11, 2010 08:19 PM
Rich06
Custom Models
Oct 23, 2006 05:40 PM
mmb617
Aug 23, 2006 08:14 PM
