99 FXST Starting problem
Old Mar 26, 2010 | 08:05 AM
DannyNY's Avatar
DannyNY
Stage III
Default 99 FXST Starting problem
Hi
New here, was looking around for a solution to this but didn't find anything so here it is..
99 Softail.. Had a hard time starting and thought it was the battery, replaced it and the same problem. Then thought it was the starter and replaced that. Still the same problem.
When I go to start it, it cranks over 4 or 5 times then stops. When I hit the button again, I here the clicking but it's like the starter is not engaging in correctly. I pulled out my meter and the battery reads 12.8v When I crank it drops to 4v and it goes up and down as it's clicking, not cranking. The cables seem to get hot as well.
I also replaced the Pos & Neg cables.. Replaced the 30amp Circuit breaker mounted on the inside rear fender. Not sure where to go next. When it was running, it was charging at 12+ at idle and 14+v at 2500 rpm. I have no accessories hooked up at this time, just the battery cables.
Can someone lead me in the right direction to get this fixed? I did get it to start once or twice but now it's just the clicking. Can there be a short somewhere?
Thanks in advance for any help..
Danny
Also wanted to add, I did check the starter relay and it was 0 so that's ok..
Old Mar 26, 2010 | 09:59 AM
sqdealgeorge's Avatar
sqdealgeorge
Your new battery might not be up to snuff With good jumper cables jump a good car bat accross the bike battery and see if the starter engages and starts the bike Did you charge the new bat say 1.5 amps for 12 + hours ?
Old Mar 26, 2010 | 09:21 PM
Tom84FXST's Avatar
Tom84FXST
That is your problem...should never drop below 8 while cranking. I would take you "new" battery back and have them check it.
Old Mar 26, 2010 | 09:54 PM
FLS2FLH's Avatar
FLS2FLH
If the battery checks OK, I'd put a fresh charge in it and get the bike to start. Then with a voltmeter, measure across the battery while slightly increasing the idle. If you arent in the neighborhood of 14volts, you probably have a charging system issue. Most likely voltage reg, stator (or both!) - or just a crappy ground. Good luck!
Old Mar 27, 2010 | 07:01 AM
DannyNY's Avatar
DannyNY
Stage III
Thanks guys for the replies..
I exchanged the battery for another one just to be sure. And it turns out after I pulled the Primary cover off again, the new starter was getting stuck out. That's why it dropped to 4v.. I reinstalled the old starter and it worked again. So I guess I got a bum battery to begin with and put out $150 for a starter that I didn't need. Thanks for the help..
Ride Safe..
Old Mar 27, 2010 | 02:45 PM
FLS2FLH's Avatar
FLS2FLH
The perfect storm of aggrivation!
Glad to hear you are back in business - a little lighter in the wallet tho. You will forget about that after a nice long ride on a beautiful weekend day! If your name suggests that you are in NY, today is NOT one of those days - the chill has returned!!
I'm just north of NYC.
Good luck!
Nitro Joe
Electrical/Lighting/Alarm
May 4, 2018 04:25 AM
Drac 1
May 23, 2013 01:37 PM
Asuperglide
EVO
Sep 15, 2011 07:53 PM
'75 Chop
Ironhead
23
Mar 2, 2009 05:28 AM
Night_Train01
13
Aug 27, 2006 10:13 AM
