A VERY embarrasing question...
Anyway.. on to the question.
My service manual doesn't tell me how much oil to put in.
My owners manual says 4 quarts if I am replacing the oil filter (which I did with a Bosch 3330)
I checked many sources online and they all say 3 quarts.
My owners manual shows the oil capacity for several 1990 models. Sportsters are 3 quarts, dyna's are 3.5 and the FLHTCU is 4.
When I drained the oil it certainly looked like 4 quarts came out.
Anyway.. I put 4 quarts in. Am I good?
Several sources online say 3 quarts.
Is it 3 or 4? It certainly looks like 4 quarts came out when I drained it.
I didn't check the dipstick after the oil change but before I started the motor the oil tank looked full. I'll check it when I get home.
So.. is it 3 quarts or 4? My guess is 4 judging by what came out.
Don't worry about your oil level, 4 quarts is what it takes - period. If you change the oil after it's been sitting a while (several days) and/or have only been run while parked on the side stand, they will often leave a good bit in the crankcase and appear to be overfull when started and run until the oil system equalizes between the flywheel side and cam side of the engine. The oil tanks on the Tour bikes are a totally different shape than the others and it's hard to overfill them to the point it'll cause any venting problems. And considering they hold so much, low oil level is of little concern either. So just do the 4 quart thing and ride a few miles and the correct oil level will reveal itself. (regardless of the mark on the stick) Also, the oil will expand and the level will vary when the oil is warm.
jgcable, I cut a little piece of cardboard and bend/wedge it over the exhaust pipe so the oil goes over the cardboard into the catch pan and not all over the exhaust pipe. Once it's not pouring out and just dripping, I pull the cardboard off and let it run down the frame, then I sit the the bike, pull it upright and let the last little bit drain out. There won't be much to clean up that way. Oh, and if your owner's manual says 4 quarts and the internet, y0, says 3 quarts, go with the owner's manual. The capacity is in your service manual as well if you have the right Genuine HD shop manual for your bike. If you don't have the right Genuine HD shop manual, that should be your next purchase.
