EVO gas mileage
Old Apr 23, 2010 | 07:23 AM
96roadking's Avatar
96roadking
Default EVO gas mileage
What kind of mileage are you guys getting with your EVOs? I had a 2002 Sportster 1200S that got 45 to 50 MPG. When I picked up the Road King, I had expected more range between fill ups with the 5 Gallon tank but I've been getting 34 to 39 MPG so not so much on the range. I need to adjust the warm idle, my timing light tach tells me it's a bit high (1210). I'm also about to put in an EV27 cam, should I expect better or worse mileage afterwards. I'm using a REvtech DFO since I'm running a 96 ECM (nonmappable), so maybe I need to play with that a bit as well. Just curious as to what others have experienced at the pumps.
Old Apr 23, 2010 | 08:09 AM
t150vej's Avatar
t150vej
Your mileage should go up with the 27 because of the different timing and lobe angles. I have no fuel infection experience, so I can't offer any facts there. But on a carbed, stock 1340 an N grind (later model stock cam) and an L grind (older model stock) gave me consistantly horrible mileage versus several aftermarket performance cams I've experimented with...
Old Apr 23, 2010 | 09:14 AM
Charlie Bone's Avatar
Charlie Bone
1998 FLHRC-I with an EV27, Power Commander (custom map done with sniffer in the exhaust), into the wind, 2 up, pulling a trailer…..get ready…..24MPG!! Normal driving was around 35 MPG and at the end I got it up to 40MPG. It did OK around town but when it got on the highway…not so good.
Old Apr 23, 2010 | 09:30 AM
Greybeard Bob's Avatar
Greybeard Bob
89 springer, EV27, Mikuni 42, I get around 45 if i don't hot rod TOO much. JMHO, YMMV, etc.
Bob
Old Apr 23, 2010 | 09:47 AM
omgtkk's Avatar
omgtkk
'99 FXR2 carbed. K&N air filter and slip-on, otherwise completely stock. I use this bike mostly around town and for riding to work. I get a pretty consistent 40-42
Old Apr 23, 2010 | 09:49 AM
phat96's Avatar
phat96
96, mine does about 42 miles a gallon. I pull in when the trip meter shows 160 miles, my gas gauge shows empty, it's the led Kuryakan one, when I get to the pump it only takes 3 1/2 gallons, so I know I could go further, but why get that floating garbage that is in the gas on the injecters.
Hope my milage is close when I do the carb conversion.
Old Apr 23, 2010 | 01:50 PM
96roadking's Avatar
96roadking
Once I get the cam in and tame the warm idle, I'll get back and post some numbers. I'm probably about average, I'm sure that high idle is sucking some fuel.
Old Apr 23, 2010 | 02:09 PM
bonz's Avatar
bonz
I put an ev27 in 87 flht and my milage jumped to 40 riding 2 up. The old cam was the L grind.
Old Apr 23, 2010 | 02:11 PM
ultrat's Avatar
ultrat
93 flh c/v carb 50 mpg 175 main jet
Old Apr 23, 2010 | 02:35 PM
meepers's Avatar
meepers
97 FLHR setup as a Streetglide. Cam, P&P, S&S Super E, Stock headers and SE slip ons was getting about 38.
Just went to True Duals, and rebuilt the carb, fixed some intake leaks. Riding to Laughlin tomorrow, will update revised mileage after that. I usually fill up at the 120-150 mark.
