hot/cold exhast gases
Old May 17, 2010 | 12:15 PM
tightlinebob's Avatar
tightlinebob
Stage IV
Default hot/cold exhast gases
Just rubuilt top end of a 84 FXRS and started it up the front cyl.has hot gasses coming out and the rear is much colder . Could this be a push rod adj. problem or a coil spark issue?
Old May 17, 2010 | 01:46 PM
96roadking's Avatar
96roadking
any other engine symptoms? loss of power from previously? rough running? Maybe an intake manifold leak or weak or no spark in the back jug but I would think it would run rough. But I, am no expert, I'm sure one will show up.
Old May 17, 2010 | 04:39 PM
miacycles's Avatar
miacycles
The front cylinder is working as it should. The rear is not working as it should. Check compression and spark, those results should get you looking in the right direction. Hope this helps.
Old May 19, 2010 | 07:37 PM
Jim Kraft's Avatar
Jim Kraft
I am not sure if EVO's do it like the older shovels, but on those they ran with different timing on the rear cyl, than on the front. They did this because the rear cyl. normally runs hotter than the front. So it may run cooler till it gets warmed up a little. My 84 Sportster was that way.
Old May 21, 2010 | 08:32 AM
tightlinebob
Stage IV
It seems to get hotter as it is ran longer .I will do a few checks today and see if i can figure it out .Thanx for steering me .
Old May 22, 2010 | 12:02 AM
hatchetman's Avatar
hatchetman
These engines are very picky on plug gap. Make sure you are at least 0.038, no more than 0.041.
Swap your plugs around as well & see if the cylinder problem moves.
Old May 22, 2010 | 05:55 AM
perpulreaper's Avatar
perpulreaper
do you run the stock pipes with the cross over my 84 glide ran that way till i put tru duals on it
Old May 24, 2010 | 05:13 PM
tightlinebob
Stage IV
I did away with the crossovers and put on a set of duals .Dont really know how it ran before the top end rebuild. It was a basket .
83hdfxrs
Shovelhead
Oct 8, 2016 03:11 PM
HighestHD883
Jul 9, 2014 06:38 PM
audettd
Jun 8, 2010 07:52 AM
Beaver 550
Shovelhead
Oct 21, 2009 08:09 AM
foxlakerider
Ironhead
100
Oct 2, 2009 03:41 PM
