EVO Head Bolt Question
Old May 21, 2010 | 09:19 AM
fester1's Avatar
fester1
Default EVO Head Bolt Question
Engine experts, I got a question concerning the head bolts/studs. In the HD manual on reassembly, I think it says to lightly oil the threads. Is there a reason for using oil specifically? Can anti-seize be used on the threads instead? Better? Worse? Thanks.
Old May 21, 2010 | 09:24 AM
96roadking's Avatar
96roadking
I have read that it is of utmost importance to have clean threads and that lightly oiling them provides a better torque reading from your wrench. I'm guessing that anti-seize may contribute to a poor torquing sequence, especially if you use too much.
Old May 21, 2010 | 11:21 AM
Dr.Hess's Avatar
Dr.Hess
Wet versus dry torque readings are different. If the spec is for wet, then you need to torque to spec wet (lightly oiled). If the spec is dry, then you do dry. Anti-seize, while close to wet than dry, isn't going to be the same as either. There really isn't a problem with the head bolts seizing up. I'd just use the oil.
Old May 21, 2010 | 01:11 PM
miacycles's Avatar
miacycles
Don't forget to put a drop of oil under the head bolt where it contacts the head.
Old May 21, 2010 | 09:02 PM
HGM's Avatar
HGM
The general idea of the oil is to simply provide a "little" lubrication in order to get an accurate torque reading by eliminating the friction element. By using anti-seize, you would be adding slick, protective coating that will not dispurse like the oil will. It can very well loosen on its own over time. So, just a small amount of oil on the threads, and like John mentioned, on the bolt head is sufficient.
Old May 24, 2010 | 10:36 AM
fester1's Avatar
fester1
Thank you for the replies!
jsbridgew
Engine Mechanical Topics
13
Jun 27, 2015 07:06 PM
batch
EVO
26
Dec 9, 2012 10:58 PM
95 Ultra
EVO
Nov 3, 2012 05:57 AM
jserigne
Ironhead
Jan 22, 2008 08:26 PM
KustimKool
Exhaust System Topics
Sep 19, 2007 05:24 PM
