Engine paint peeling
Old Jun 4, 2010 | 05:14 AM
nwilliams's Avatar
nwilliams
Stage IV
Sometime there are also kind of dirt paints which may cause peeling. There are various treatment are going on for the peeling problem. Peeling paints problems come out due to some organic compounds.
Old Jun 6, 2010 | 04:33 AM
Hogjob's Avatar
Hogjob
I just did mine, the PO had brush painted the engine!!
I used VHT Engine Enamel. Had the jugs and heads bead blasted first, then masked and sprayed.
I used a heat gun to cure the paint to make sure it was tough enough for rebuilding.
Then used a dremel and fine abrasive cylinder to do the edges.
Cheers.
Paul.
Attached Thumbnails Engine paint peeling-imgp0963-640x480-.jpg   Engine paint peeling-imgp1128-640x480-.jpg   Engine paint peeling-imgp1155-640x480-.jpg   Engine paint peeling-imgp1193-640x480-.jpg
Old Jun 6, 2010 | 11:22 AM
Buddy WMC's Avatar
Buddy WMC
Nice work!!
Old Jun 8, 2010 | 07:53 AM
cajunKen's Avatar
cajunKen
6th Gear
Originally Posted by NorthGeorgiaHawg
I didn't even sand the paint off of the outer edges of the fins because I like them all black anyway. Makes her look different. Easy to touch up, too...
X2 I like the all black look too....I repainted mine (inner primary, cylinders & cases) after doing the clutch a couple of months ago...hopefully it'll still look good in a couple years
Old Jun 8, 2010 | 12:18 PM
mp's Avatar
mp
Yeah, they all do it. I don't do a very good job of sanding, so I have to touch mine up every year. Be sure to cover up everything you're not painting.
Old Jun 11, 2010 | 09:50 AM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
Thanks. My inner has a chrome Kury cover on it, so I didn't bother with that, and I have a tranny interface cover, too. I've noticed that Bertha needs a touch up... but 500 degree engine rattle cans paint is cheap. If I have to tocuh her up every year or so, I'm OK with that.
+1. Spray paint has nasty habit of landing on lots of places where it's not wanted! I clean everything well with degreaser, mask everything off, spray in the driveway so any overspray largely drifts away from the bike, wait for precisely two beers, then carefully take the masking off and clean up any overspray with mineral spirits. The uncured paint comes right off!
I have found that a third beer makes the unmasking and cleanup process much more enjoyable, too!
Old Jun 14, 2010 | 02:43 PM
89 FXRS's Avatar
89 FXRS
I have never seen a motor repaint on a older Evo that looked good close up. The cylinder paint does not match the cases, etc.
I was lucky I guess. I had a oil leak on the rear cylinder bottom. So I pulled both cylinders and replaced the rings to freshen the motor. Before installing every thing I took paint remover and removed all of the paint on the heads and cylinders.
I saw others do the same thing and thought it looked much better than repaints. I like it much more. It looks better and I do not have the hassle of peeling or fading paint.
Old Jun 14, 2010 | 09:20 PM
iceman0084's Avatar
iceman0084
Just painted my whole motor/transmission with a paint brush and 500 degree flat black engine paint. took about 8 hours total, including sanding the fins. made a huge difference.
I Don't have a before pic but was all painted with a thin paint brush and used emery paper to sand the fins down
Old Jan 23, 2014 | 09:40 AM
Clokey82's Avatar
Clokey82
Stage III
I Know It's Been A While, But I Am Hoping You Can Remember What Brand Satin Black Paint You Used To Paint ThIs Engine.
I
Originally Posted by HGM
Here's a couple of pic's of mine when I did the top end. One pic is the faded jug's, another shows the black fins and the other is sanded. I used satin finish engine paint and baked it on. Obviously, you cant put the whole bike in the oven, so, when I did the case, I used a space heater to bake it. If you do it on a weekend that you can ride, once its dry to the touch, I'd go for a ride to bake it on. There's better ways, but not everyone has the time or resources to tear it down to do it at will. So, this works well in the interum.
Old Jan 23, 2014 | 09:54 AM
falconbrother's Avatar
falconbrother
When I bought my 1988 the paint was completely gone in places. I was washing it one nice early spring day, grabbed a can of flat black rustolium and a couple of brushes and went to work. I never thought it would last very long but, it still looks great. I didnt tape anything off, I was just real carefull not to get any on silver pieces. I used little brushes for the tight places and a slightly bigger brush in not so tight pkaces. I also grabbed a can of gloss and hit the less than shiney and rusty places on the frame to touch them up.
Now that's a redneck fer ya.
