Sticking lifter - time for cam change?
Thanks,
Bogey
Thanks,
Bogey
Since you said mid-range power and not low-end power - an Andrews EV-27 or V-Thunder EVL-3010 cam would seem to be in order. The EV-13 is made for heavy bikes and kicks in at a lower RPM than the others - so if you like to lug your motor to get that "Harley sound" and want good stoplight acceleration off idle without winding the motor up to 3000+ RPM, then you might like that cam better. But it won't pull as strong at 3000-5000 RPM.
I run the EVL-3010 and I like it, but it likes some revs, and Bertha still pings at under 3000 RPM, even on premium gas. I'm backing off my timing advance (Daytona Twin Tec ignition) slowly until it stops, but I haven't gotten to that point yet. I'm at 5 on a 10 point scale now. Next stop, 4 - even though Daytona recommends 7 on premium... go figure. All the downshifting to get revs is starting to wear on me... so I may adjust the pickup in the nose cone to retard it a bit. Pinging is BAD!
I will say that the EVL-3010 has delivered EXCELLENT gas mileage... I get north of 45 MPG on a 900-pound unladen machine, and I ride pretty... umm... aggressively!
Lots of cam threads here, and excellent instructions on replacing a cam at nightrider.com.
And, as the Good Doctor said, be sure to replace the cam bearing with a Torrington!
It's the successor to the EV-1, with the intake timing advanced 3 degrees, same .485 lift, with the EV-1 also having .485 lift on the exhaust as opposed to the 13's .495, and the EV-1 opens the exhaust valve 11 degrees later than the 13, with 12 degrees less exhaust duration total. By the way, the EV-1 doesn't resemble either of the 80's EPA Evo cams in the slightest.
My own experience after many tens of thousands of miles with the EV-13 is much improved power at all rpm, with slightly improved fuel mileage. (Despite constant "lugging" of the engine.)
I use Crane lifters, having no faith in the H-D variety, although the B numbers are supposed to be improved.
