primary chain
Old Jun 18, 2010 | 09:00 AM
sbrn33's Avatar
sbrn33
Default primary chain
Just took my bike(98 fatboy) in for a service at 26,000 miles. shop called and told me the Primary chain is loose and at the end of the adjustment. It will need to be replaced at a cost of around $200 does this sound about right?
Thanks Scott
Old Jun 18, 2010 | 09:47 AM
oldbiker771's Avatar
oldbiker771
Somebody must have overtightened it, they are good for 100k normally.
Old Jun 18, 2010 | 11:49 AM
t150vej's Avatar
t150vej
Thanks Scott
It is unusual for them to be stretched that much that soon... nonetheless, a high quality chain is about 65-75.00 (at least) so the labor doesn't sound too bad and I don't know what HD is using now for replacements, but they were using Regina brand which is not so great. So if it's at a dealer (or not) ASK the brand name before giving the go ahead. Tsubaki or Diamond are the prefered brands.
Old Jun 18, 2010 | 01:02 PM
Tucson_Tim's Avatar
Tucson_Tim
Wouldn't adjustment that tight be hard on the shaft bearings also?
Old Jun 18, 2010 | 05:04 PM
SportsterBob's Avatar
SportsterBob
A primary chain will wear out quickly if the outer clutch hub is not properly aligned to the primary drive sprocket.
Old Jun 18, 2010 | 05:28 PM
Tucson_Tim's Avatar
Tucson_Tim
Would that be a manufacturing/assembly problem from the factory on a new bike or more likely a problem someone injected into the primary drive assembly?
Old Jun 18, 2010 | 05:42 PM
SportsterBob
YES to both!! There seem to be many who have issues with primary noise on new bikes..That being said, it all depends on who is assembling the primary at the factory and who works on at the local bike shop...
There are Mechanics and there are parts swappers/assemblers...
There are MORE parts swappers/assemblers out there with each passing day!!
Old Jun 18, 2010 | 06:44 PM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
+1! A good, experienced mechanic is a good person to know! Parts assemblers know "what", but a good mechanic knows "with what", "why", and "how"!
Old Jun 18, 2010 | 06:53 PM
SportsterBob
The parts swapper changes parts and gouges you...
A Mechanic fixes problems and builds a steady customer base.
Pick your source carefully.....an honest one is hard to find!
Old Jun 18, 2010 | 10:23 PM
Beemervet's Avatar
Beemervet
Ain't that the truth!
And don't get me started on parts counter guys!
