Charging system
Old Jul 29, 2010 | 12:24 PM
mtnlvr's Avatar
mtnlvr
I'm having the same problem starting yesterday. Here's a link to my thread (unfortunately no suggestions though...just symptoms).
Another symptom I'll add is that with a volt meter hooked up I'd get 13V at the battery. With the engine running above idle I'd get 14.5V. When the tach and lights start freaking out, so do the volts...bouncing from 14.5 down to 8 or so. Kill the engine and it reads 13V again.
After a couple hour cool down I go back out and read 13V. Turn on the ignition and nothing...not a light, flicker, twitch of a guage, click of a selenoid...and the voltage drops to pretty much zero on the meter. Turn the ignition off...back to 13V.
Is yours doing the same pt?
Old Jul 29, 2010 | 12:44 PM
Dr.Hess's Avatar
Dr.Hess
Short somewhere, or a bad battery, mtnlvr.
Old Jul 29, 2010 | 12:52 PM
mtnlvr's Avatar
mtnlvr
To be clear, I'm not trying to hijack your thread pt, just trying to help us both I guess.
Dr., not sure if you read anything from my above linked post, but I also go zero ohms across the stator plug. The 2005 vintage battery is at the shop to get load tested...pretty sure it's toast. I'd just like to know if it's toast from age / vibration or the charging system.
Old Jul 29, 2010 | 12:55 PM
tombeving's Avatar
tombeving
At 2500 rpms, your stator should be putting out 42 volts AC. If you are only getting 28 volts @ 2000rpms, I would say replace your stator.
Old Jul 29, 2010 | 01:05 PM
Dr.Hess's Avatar
Dr.Hess
Yes, I read your thread, that's why I said short or the battery. Your further information that the battery is 5 years old means that should be replaced regardless. 0 ohms across the stator is difficult to measure. You need a pretty good meter to determine if the resistance between the pins is within factory spec. Open is pretty self explanatory.
Old Jul 29, 2010 | 07:10 PM
mtnlvr's Avatar
mtnlvr
As suspected, battery shot. Got a new battery in and checked stator while running, 40-45V at or just above 2k rpm. I'd road test it, but I need new rear wheel bearings. Hopefully tomorrow night or Saturday night.
Last edited by mtnlvr; Jul 29, 2010 at 07:14 PM. Reason: I don't know what day it is.
Old Jul 30, 2010 | 11:49 PM
ptcruiser's Avatar
ptcruiser
mtnlvr
Glad you got yours figured out. I just got a package in today with a new stator ,rotor and regulator. I'm just going to go through the complete system and hope that will fix it.I tried a new bat with no luck.. I will post results when finished Hopefully tomorrow.
Old Jul 31, 2010 | 11:21 PM
ptcruiser's Avatar
ptcruiser
Got new parts installed today and It charges better then it ever has
The only thing that I could find was the rotor had been rubbing on the stator, There was some pretty harsh looking marks on the rotor and the stator had two of the fields shined up from the contact. I guess this would explain the noise I was hearing .
Old Aug 1, 2010 | 10:45 AM
mtnlvr's Avatar
mtnlvr
Very nice. Now get out on the road and hit some twisties!
Old Aug 26, 2010 | 08:15 PM
Tactical111's Avatar
Tactical111
Thumbs up
Originally Posted by ptcruiser
Yes i double checked that setting on my meter and have been on 200k so switched to 200 scale and am getting 0.7 but when touching the leads together I get 0.6. I have messed with it for couple hours retracing all the steps. When connecting one lead to ground and the other to the pins of the regulator I get 0.33 at each pin. I hooked everything backup and the symptoms I described earlier with the lights dimming and tach going crazy does not happen now for some reason. Check voltage at the bat 12.6V nothing on turn key on 12.2V startup and the most I can get is 12.5V at 3000RPM. Thinking of just replacing rotor stator and reg.
Dimes to dollars it's your voltage regulator. I'm on my second after market one in 22k miles or so. It tested fine in the garage but my new Die Hard battery gradually ran down on the road until I lost turn signals and headlights. New voltage regulator and problem gone. Also ran a ground wire from the regulator body direct to the neg. battery terminal and rubber mounted the regulator per one blogger on here. Just used old barrel gasket rubber to do it. Also installed a neat little voltage monitor next to my console so now with a glance I can see the progressive colored leds that tell me what the charging system is doing. Got it at JP Cycle for about $40 and it is very cool to be able to glance down and see electrical system operation.
