Help with tick noise PLEASE!
Well, I did mine with a hydraulic press at work. Easier to install, as you can warm up in an oven to 180 degrees or so and it'll slip on and be tight once cooled. You do need to ensure it's indexed properly for timing. At this point, if I were you, I'd wait to find out if your indys' work helps at all before you decide.
I dropped it off today. He is going to look at it monday. It was making the noise when I left it and he listened to it. He said he would go back through and readjust the pushrods and check the exhaust gaskets. He said it may be a bad lifter. I guess I will see what he says. No charge for the readjust but if the lifters have to be replaced again I will have to pay for it. May do it myself. I am just pretty sure it is going to be the cam gear and I dont' have the stock gear to swap out how hard is it to replace the pinion gear?
Ultima will replace a defective lifter at N/C depending on where you bought them and if you have proof of purchase. They will not however pay for the labor to replace the lifter. Never heard of a V-Thunder or S&S lifter failure, so you might want to consider that next time.
TO34
03-08-2012 09:04 PM
