Diaphragm spring adjustment
Old Aug 11, 2010 | 01:30 PM
Tomcatt78's Avatar
Tomcatt78
Default Diaphragm spring adjustment
Is there a way to check the diaphragm spring adjustment? The manual says to use a straight edge against the adjustment plate and measure the distance to the compression spring with a feeler gauge but I can't figure out what they mean and there is no picture in the manual. Also, there is a blue line marked on the spring so is that an indication of where the spring should be positioned?
Old Aug 12, 2010 | 12:19 AM
miacycles's Avatar
miacycles
the blue line is a mark to tell you which spring you have. Do you have a Clymers or Harley Manual?? Year and model of Bike???
Old Aug 12, 2010 | 08:37 AM
Tomcatt78's Avatar
Tomcatt78
The bike is an '85 FXRP. I have a Harley manual
Old Aug 12, 2010 | 10:44 AM
Dr.Hess's Avatar
Dr.Hess
I'm looking at the Harley manual right now for 84-86 FLT/FXR Models. It says "5. See Figure 6-20. Place a straightedge..." and figure 6-20 shows a straightedge and has everything labeled as to what's what.
Old Aug 12, 2010 | 05:27 PM
Tomcatt78's Avatar
Tomcatt78
I saw that part. I'm trying to figure out how to get a straight edge across the plate without having to take off the primary cover. I noticed that when I pull in the clutch lever, the plates do not push out evenly. Only one side of the plates will push out.
Old Aug 12, 2010 | 06:25 PM
miacycles's Avatar
miacycles
Go to Loews and purchase a short piece of flat steel or aluminum, cut id down to the appropriate size, label it, then drill a hole in it so you can hang it up and be able to find it next time.
Old Aug 12, 2010 | 06:51 PM
Uncle G.'s Avatar
Uncle G.
Or just go to Lowe's or Sears and get a 6" machinist's scale.
Old Aug 12, 2010 | 09:06 PM
Dr.Hess's Avatar
Dr.Hess
Humm. That doesn't sound right to me. Maybe that's your problem here. What you guys think? Broken spring?
Old Aug 13, 2010 | 07:08 AM
Tomcatt78's Avatar
Tomcatt78
Thats what makes me wonder if that blue line on the spring is some kind of alignment mark.
JeremyB
EVO
20
Nov 23, 2017 09:02 AM
cocheese72
Jun 18, 2015 12:52 PM
SaltyHawg
Mar 18, 2010 09:55 AM
Hickey
Dec 16, 2009 10:29 PM
big mahk
Screamin Eagle CVO Models
Dec 10, 2007 12:15 PM
