Fried voltage regulator!
Old Aug 20, 2010 | 03:19 PM
mjaw's Avatar
mjaw
Unhappy Fried voltage regulator!
Was out riding today. At stop sign noticed smoke coming from front of bike. Upon looking further, it was the voltage regulator. Quite a bit of smoke coming from it. Wires from the stator to the regulator were quite hot! After shutting off, bike would not restart. Wouldn't even turn over. 1998 Dyna Superglide w/ 21,000 miles, always kept in basement. Please note: prior to riding, bike was on battery tender jr. for approximately 24 hours and I washed it about 1 hour prior to ride. What are the possible causes of a "fried" voltage regulator? Any advice would be greatly appreciated.
Old Aug 20, 2010 | 04:08 PM
Dr.Hess's Avatar
Dr.Hess
Sometimes they just go bad. Sometimes a short somewhere else will take them out. Go through my guide
https://www.hdforums.com/forum/7049417-post2.html
and check the stator. We already know the regulator is shot because you let the smoke out.
Old Aug 20, 2010 | 08:31 PM
96roadking's Avatar
96roadking
At work we call it "magic smoke". All the black box electronics contain this. If you let out the magic smoke, no more magic left in the black box! Time to replace it.
Old Aug 20, 2010 | 09:10 PM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
Magic smoke! LOL!
I recommend you go to your local H-D dealer and get a Genuine H-D regulator for about a Hunnid Dollahs! The one on Bertha lasted 15 YEARS before I finally had to replace it about 6 weeks ago... after an embarrassing 40-mile tow truck ride home when the battery lost enough juice to no longer be able to run the bike after the regulator failed. I put a new Genuine H-D regulator on in about 30 minutes, and all is well again.
Normally, nothing will burn out a regulator except an internal failure in the regulator itself. The regulator's purpose is to take the varying level of AC voltage coming from the stator (typically 16-20 VAC for each 1000 RPM), and feed a constant metered voltage to the battery to keep it charged but not burn it up.
Old Aug 20, 2010 | 11:59 PM
BB4xl's Avatar
BB4xl
Zanotti's? I you don't mind waiting.
https://www.zanottimotor.com/shopping/pLookUp.php
Old Aug 21, 2010 | 06:45 AM
mplecha's Avatar
mplecha
Now's your chance to put a cycle electric kit on. My original regulator lasted almost 10k miles. The cycle electric kit isn't much more than HD, but it's worth every penny!!
Old Aug 21, 2010 | 07:49 AM
IronGear's Avatar
IronGear
Originally Posted by NorthGeorgiaHawg
Magic smoke! LOL!
Really bad advice here, that will most likely waste your money.
There are lots of things that can impact the reg/rec, and cause it to burn out.
If you just replace the item, then it could happen all over again. AND QUICKLY.
Even if the stator still appears to be ok, it is almost certain that there will be some damage, and that things could get expensive again.
You need to check it all out really well, before you buy anything.
If your battery is a bit sad, the reg/rec is no longer servicing a really good battery. It is designed to supply only a trickle type charge. If it has to prop up a dying battery, it will feel the pain. Remember, volts and amps are in direct inverse proportion.
Sardo
May 7, 2017 10:42 AM
Arjeje
General Topics/Tech Tips
Feb 18, 2016 10:21 AM
lizard86
Electrical/Lighting/Alarm
Aug 7, 2014 11:36 PM
96RK
Dec 18, 2011 06:24 PM
TravelingBiker
Oct 12, 2009 09:41 AM
