No charging voltage!!
Old Dec 16, 2011 | 07:22 PM
96RK's Avatar
96RK
Stage III
Default No charging voltage!!
Just picked up a 96 Rk, I have no charging voltage.
What i did is measure battery voltage before starting 12.5v then after
she was warm @ idle battery 12.3v. If i keep the rpm around 2000-2500
still nothing. Any suggestions? Was thinking voltage regulator?
Old Dec 16, 2011 | 07:47 PM
Dallas 13's Avatar
Dallas 13
To know you need to check the output of the stator - not exactly sure of your model, but should be over 20 volts AC out of the stator to the regulator. If you have stator voltage, the regulator is suspect. Ought to be around 14 volts DC out of the regulator at 2000 rpm.
Old Dec 16, 2011 | 07:59 PM
96RK's Avatar
96RK
Stage III
Thanks its a flhr 80 evo.
Ill check that and let you know the results.
Old Dec 17, 2011 | 07:41 PM
96RK's Avatar
96RK
Stage III
Ok Dallas I pulled the connector for the voltage regulator and measures 24v ac from the stator at about 1500 rpm. So I guess i need a new voltage regulator.
Thanks
Old Dec 17, 2011 | 07:48 PM
mkguitar's Avatar
mkguitar
there is sticky on the tech board electrical section.
in short you should see 16 to 20 volts AC per 1000 rpm at the stator.
you already did that check, but run the rpms up higher and make sure that the output meets specs
3000 rpm should see 55 or 60 volts.
to check regulator, first check connections- stator plug, regulator mount ( ground) and the + wire from the regulator to the battery- this sometimes gets damaged by road debris.
mike
Old Dec 17, 2011 | 08:29 PM
jmacdonald5's Avatar
jmacdonald5
...sounds like regulator...your lucky day! (compared to having it be the stator)....
Old Dec 18, 2011 | 06:24 PM
Dallas 13's Avatar
Dallas 13
Check the voltage of the battery with bike not running. A good battery should read 12 to 12.5 volts. Restore all connections to normal and you should have around 14 to 14.5 volts at the battery at 2000 rpm. If you continue to only see battery voltage, bad regulator or wiring from it to the system.
Powertrip240
Jun 21, 2015 12:55 PM
Michael Gamboa
Electrical/Lighting/Alarm
Apr 25, 2014 06:58 AM
hellboyrich
Mar 6, 2011 11:52 AM
timberwolfz28
EVO
Jun 25, 2009 09:05 PM
gsparesa
Nov 14, 2005 01:29 AM
