Timing and mileage
Old Aug 24, 2010 | 04:07 PM
98fat's Avatar
98fat
Default Timing and mileage
Hey, can timing really effect mileage? Put new Mikuni in and am running about as lean as I care to. Plugs look OK (white to tan so a little lean) Idles pretty rough until warm almost like it is missing but runs fine once warm. I have the idle jet just one turn off of all the way in (rich) otherwise idles rougher. Still getting low 30's on the highway. Doesn't seem to make sense, thought it would do better. No pinging, surging etc..... Not much else to check other than timing. Thoughts?
Old Aug 24, 2010 | 07:21 PM
miacycles's Avatar
miacycles
Go one size larger on the low speed, The idle screw shold be about two turns out. Check to ensure that the enrichner is seated all the way as that will make it run rich, causing poor mileage. Check for air leaks, set accelerator pump at .081. Also check float level as it can be changed due to rough shipping and if the level is off it can affaect the jetting. Yestiming can affect mileage, did you change it?? Hope this helps.
Old Aug 25, 2010 | 02:27 PM
98fat's Avatar
98fat
Hey thanks for the reply, I did check the enricher and it is OK. I did try the 25 pilot and it pretty much behaved the same way as the 20 I have in now. No intake leaks, new exhaust and seals. Haven't checked float, I should of last time I had it off. No, I haven't messed with the timing, that is next. Going to adjust the timing and live with it... Thanks.
Old Aug 25, 2010 | 02:49 PM
Kabear's Avatar
Kabear
You might want to check your actual mileage against what ever mileage measurement you are using...just a thought.
Old Aug 25, 2010 | 03:21 PM
miacycles's Avatar
miacycles
Don't forget to check the accelerator pump rod clearance, too close and it will come in too soon and too often making for poor mileage. You should be getting about 40- 45 MPG at least. Of course it all depends on how and where you ride !!!
Old Aug 25, 2010 | 04:53 PM
Jim Kraft's Avatar
Jim Kraft
Check you VOES. If it is not closing, your timing would stay retarded, and knock down mileage. My 99 EVO gets around 46 to 50 mpg with a 45 pilot, and a 185 main.
Old Aug 26, 2010 | 12:18 AM
RidemyEVO's Avatar
RidemyEVO
I ran my bike most of this year with a bad voes then changed it and can't believe the differnce in performance and gas milage.
Old Aug 27, 2010 | 08:00 PM
beedub's Avatar
beedub
6th Gear
was that the 1989 FLHTP? I'm puttting one back into good riding condtion, had 96000km when i bought it, 103000 now :-).
I took it to an older mechanic and gave him a cheque to look it over, maybe change lifters, do anything to ensure it was ok. spent $400, new top end gaskets, lifter gasktes , etc, - he said there was so little wear everywhere (it had been running strong on synthetic when i got it from a cop who had the total bills for a complete tranny overhaul) that it was either an excellent rebuild or a new motor. only snag was preignition, lean with true duals and stock keihin, replaced compliance fitting and way too hot plugs, been running very well except some pinging if I have to use 91 octane. other wise with 94 octane all is well- big differnence in accleration with gas. wondered about voes but starts perfect, accelerates snappily, only pings going uphill at high speed with load, so i dont do that. ( like high). wonder if voes renbew would be een better. hmm. mileage about 35, i drive it aggresive.
worstdayever
Carburetor Related
Sep 26, 2018 09:18 AM
jokenroll
EVO
28
Sep 25, 2012 10:50 AM
Mr1986FLST
EVO
Jun 21, 2012 12:11 PM
srm148
Jul 4, 2008 08:28 AM
corpsmanp
Apr 8, 2007 10:29 AM
