1984 FLHTC muffler
Old Sep 5, 2010 | 01:23 AM
gnafin's Avatar
gnafin
Default 1984 FLHTC muffler
i need new mufflers for my 1984 FLHTC... this has the band, strap aroung the muffler... what can i use?
Old Sep 5, 2010 | 04:54 AM
grbrown's Avatar
grbrown
You may struggle to find any new ones that will fit. I had the same system on my 1990 bike and now use a later set of pipes and mufflers, with the later more universal style of clamping.
Old Sep 5, 2010 | 08:53 AM
big cahuna's Avatar
big cahuna
When I had my '93 it had the old style mufflers also. What I did was to carefully cut the raised end off the pipe. As close as you can possibly get , then you can use the newer style slip on mufflers. The left side has to be tightened real good or the tend to slide off.,,
Old Sep 5, 2010 | 11:40 AM
gnafin's Avatar
gnafin
so, use newer muffler but cut off the mounting stud? then just use my old clamp on the back?
Old Sep 5, 2010 | 06:48 PM
Dr.Hess's Avatar
Dr.Hess
I think bc means to cut the flange off of your exhaust pipe. The part that the strap clamp goes around. Then you can use a "modern" slipon with your existing head pipes (the crossover of which is probably cracked now anyway). A better option is to buy an entire new exhaust system off a twinky, like a 07 FLHT_whatever and use the whole new system instead. That's what I did. It was like a bill on eBay, delivered and fit perfect.
Old Sep 8, 2010 | 10:03 AM
big cahuna's Avatar
big cahuna
If you haven't decided what you want to do, and would rather stick with the original type mufflers, my friend has a set. Don't think there showroom quality, but they aren't rusty or dented. Let me know.,,
Old Sep 14, 2010 | 02:29 AM
IDIDNTDOIT's Avatar
IDIDNTDOIT
Hey, don't get here much lately, I have a set with turndowns.. the baffles are a little deteriorated, they bark pretty good!!!! My front pipes were dicolored so I picked up a set from a local guy off his 08 RK. I plugged the O2 holes and begged a set of stainless big ovals a buddy had on the shelf. $50 plus shipping would get the turn down set to ya.
Old Sep 14, 2010 | 10:12 AM
rivercityslim's Avatar
rivercityslim
When I updated my exhaust a few years ago, I got a Fullsac true dual kit and found some Cycle Shack slip-ons (with the 'woven stainless steel sound blanket') that were made to fit the pre-94 pipes. They are three or four years old now and still look and sound great. I bought them online, but can't remember where. I know that pipecity.com carries Cycle Shack; don't know which particular ones (slash up/down/out, straight cut etc.). This pic is from earlier this year, so the mufflers were over three years old at this point:
Old Sep 27, 2010 | 07:24 AM
wulffe's Avatar
wulffe
You will probably have to replace the saddlebag support rails; the 84's and some 85's had an odd mounting setup. New rails - right = 90781-85 and left = 49194-85
magna3500hd
Milwaukee Eight (M8)
Sep 13, 2017 08:08 AM
Kirbybell
Exhaust System Topics
May 14, 2013 02:09 AM
Screw62
Feb 7, 2013 01:11 PM
Cruisin1966
Samson Exhaust
Nov 7, 2010 12:14 AM
speedglide
Aug 23, 2009 01:57 PM
