Rear brakes
Old Nov 14, 2010 | 06:28 AM
chrome one's Avatar
chrome one
Stage II
Default Rear brakes
Has anyone had a problem with excessive rear brake pad wear on a 1999 softail?rear brakes have allways been touchy and lock up easily.rotor looks good.have had this bike for 8 years. Original owner replaced rear caliper.do you know of any problems with brakes on this now old evo fatboy.thanks
Old Nov 14, 2010 | 08:24 AM
bikerlaw's Avatar
bikerlaw
The rear brake in my '96 was hanging up just a little bit when I first got it. I installed new pads, sucked out all the brown and grungy fluid from of the reservoir and bled an entire bottle of new brake fluid threw the system. Finally the new fluid started to come out the rear caliper crystal clear. That solved the problem for me.
Old Nov 14, 2010 | 10:27 AM
grbrown's Avatar
grbrown
In addition to bikerlaw's advice, clean the caliper where the pads fit and make sure they are not hanging up and dragging. If need be clean the exposed parts of the piston, so it retracts fully. Above all else, change the fluid!
Old Nov 14, 2010 | 11:05 AM
RidemyEVO's Avatar
RidemyEVO
Definately absolutely flushing out the fluid makes a major differnce.
Old Nov 14, 2010 | 01:13 PM
miacycles's Avatar
miacycles
Yep flush the fluid and ensure that the bracket/caliper is free to float back and forth, so that it centers on the rotor. Hope this helps.
Old Nov 14, 2010 | 02:27 PM
chrome one's Avatar
chrome one
Stage II
Thanx,never thought to flush out all the fluid.cant wait to see what happens.ill get back to ya
rideflhr
Feb 23, 2017 06:56 AM
vbhousehunter
Wheels/Tires
Nov 4, 2012 08:31 AM
glidingwide
Nov 15, 2010 11:08 AM
clarsen2020
Wheels/Tires
Jul 22, 2010 07:32 AM
jawja
Sep 30, 2008 11:53 AM
