Fork Wobble
Old May 22, 2011 | 08:55 AM
Whiskers's Avatar
Whiskers
This is a great thread, thanks to all who have contributed. Recently I started noticing on slow speed turns that my front end wanted to 'flop' over. I guess what I call flop others call wobble? I rarely have my bike over 80 mph so I'm trying to figure out whether the comments I read about wobble at that speed can be translated to my slow speed turns?
Anyway, I stopped at the dealer yesterday to make an appointment - its all a bit unnerving to think about what could happen at highway speeds. As for the bike, I do have some uneven tire wear on the front tire and that is where I most logically would have started (a balance weight fell off the wheel sometime ago). However, reading your comments there appear to be many other places to start. To their credit, the service techs suggested many of the things you guys have already posted - tire, spokes, wheel, neck bearings and motor mounts. My bike has 33k on it and the tire has about 6k. Thanks again for your comments. Its great having a place where others have experienced these problems and are helping others stay out of trouble.
Ride safe.
Old May 22, 2011 | 05:51 PM
aussie dave's Avatar
aussie dave
G`Day All.
I am also getting the dreaded "wobble", I rode Sportys for yrs and a Superglide before i picked up my old Arm chair so I was real suprised when she tried to throw me off the road through some bends.
The bike has new tyres/wheel bearings and front forks rebuilt by previouse owner and myself, I talked to some mate's and checked out the Aus Harley Forum and found that a few bloke's are useing the Glide-pro setup, so I went to there web-site and watched the vids and ordered a set, they should arrive this week so after I install them and ride a few hundred kays i will post it up.
Aussie Dave.
Old May 22, 2011 | 08:30 PM
Dr.Hess's Avatar
Dr.Hess
Check the neck bearing. The procedure is in the book, but basically, undo the clutch cable at least, front end up, turn wheel one way, let it go and count the oscillations. Biatch to adjust, but that's what caused me to have a wobble. I also stopped pulling the front wheel off the ground and stopped having that bearing go out of adjustment and stopped eating drive belts.
Old Jun 3, 2011 | 01:48 AM
aussie dave
Well I installed the Glide-Pro setup last friday, i have only put 180kays on the bike since the install...but the harley wobble is 90% gone...I am rapt.
Rideing the same mountain roads at the same speed there is no wobble, sure I can try to push it at stupid speeds and she will wobble...but hey i aint rideing a Buell.
Bike feels alot better at all speeds, change of direction and bumps in corners are more controllable.
I did check the neck bearings as suggested by Dr.Hess before I installed the glide-pro, and yes they were to loose and ajusting them correctly did help minimise the wobble, so if you know your
front engine mount and swingarm rubbers are fairly new or in good condition I would advise neck bearings 1st, all my rubbers were shot...front mount had a split all the way through and s/arm
rubbers were a mess.
Aussie Dave
Old Jun 3, 2011 | 04:32 AM
NutterFLH's Avatar
NutterFLH
Better check Your wheels alignment. And drive train alignment since the rear wheel is bolted to it through swingarm. I did it on my EG and the wobble is gone.
Also I experienced some wobble on my friend`s Yamaha FJ11 which is 120BHP bike. Checked rear wheel - it was out of line. Set the alignment properly and the wobble was gone. Having wobble at 120-130MPH was no pleasure at all.
Old Jun 13, 2011 | 11:24 PM
roamin' iron's Avatar
roamin' iron
6th Gear
Adjust the steering head nut first. tighten it 3 or 4 tabs and test ride. I would bet your problem goes away. It did on mine. It's cheap and easy.
Old Jun 14, 2011 | 02:31 AM
Holster Maker's Avatar
Holster Maker
Interesting video about the wobble.
http://www.kpho.com/local-video/inde...deo_id=4697488
vinzilla
Jun 6, 2016 09:53 PM
lewk
Feb 18, 2013 10:58 PM
ryderbiker
Dec 10, 2012 06:36 AM
jmltinc
Apr 16, 2011 04:46 PM
slack20
Jul 2, 2007 03:45 PM
