starter bushing change
Old Jan 28, 2011 | 07:33 AM
schoolmaster's Avatar
schoolmaster
5th Gear
Default starter bushing change
Hi , I've got an 89 flh. Does anyone know if I can change the bushing in the inner primary that the starter jack shaft turns in without removing the inner primary?
How's that done?
Old Jan 28, 2011 | 09:18 AM
jsbridgew's Avatar
jsbridgew
don't think so... that baby needs to be pressed out, so removing the inner primary is necessary
why are you replacing it, anyway? ...damaged?
Old Jan 28, 2011 | 10:15 AM
schoolmaster
5th Gear
the starter attempts to engage but catches or binds . a little push on the starter ,or is the solinoid ,will take care of it . I had another starter to swap out but still catches. I found a little never seize outside the rear seal on the jack shaft buys me a number of goood starts
Old Jan 28, 2011 | 10:34 AM
jsbridgew's Avatar
jsbridgew
yah, you could have damaged it with all the false starts... especially if the jackshaft was jacked while attempting to make the grab
agree with you about the never seize
Old Jan 13, 2025 | 08:22 PM
rob cantu's Avatar
rob cantu
6th Gear
Default Tools?
What tools you use to remove the
Inner Primary Starter Shaft Bushing?
Litten Racing
Jan 14, 2025 07:32 PM
Just Cause
Oct 21, 2012 02:43 PM
jarrette
Shovelhead
Oct 1, 2010 06:50 PM
tsm1550
Jul 10, 2010 08:54 PM
calex3517
EVO
May 2, 2009 10:23 PM
