se heads install question?
Old Feb 3, 2011 | 05:48 AM
swensos's Avatar
swensos
Default se heads install question?
If we're going to swap to SE Heads and an EV27, will we need the adjustable pushrods?
Old Feb 3, 2011 | 06:18 AM
Mike T's Avatar
Mike T
There's nothing wrong with using the stock pushrods. The adjustables are just more convenient. If you need or want to change a cam out later you don't have to pull the heads to do it.
Old Feb 3, 2011 | 08:29 AM
98 FLHX's Avatar
98 FLHX
Might want to change the factory valve seals....when I installed SE heads on my old FXR, the factory seals were leakers right out of the box.
The SE heads will benefit from a quick clean up (polish), and they will perform well.
Old Feb 4, 2011 | 12:39 AM
1997bagger's Avatar
1997bagger
expecially the valve seals
Old Feb 4, 2011 | 12:55 AM
hatchetman's Avatar
hatchetman
Pull your cam bearing while your in there. that little piece will destroy your whole engine if it comes apart!
Old Feb 6, 2011 | 03:04 PM
phat96's Avatar
phat96
subscribed:
nallac
EVO
11
Jan 11, 2024 05:24 PM
Z'Stein
Engine Mechanical Topics
Jun 21, 2019 11:31 AM
TODDNVAL
Nov 13, 2008 12:49 PM
snip0721
Exhaust System Topics
11
Dec 25, 2007 09:54 AM
fiddledicksr
Dec 3, 2005 07:15 PM
