Inductive Tachometer advice
Old Feb 18, 2011 | 10:31 AM
carlgrover's Avatar
carlgrover
Default Inductive Tachometer advice
I want to get an inductive tach for my 98 FI, RKC like this one:
http://cgi.ebay.com/ebaymotors/ws/eB...m=190459698125
any suggestions on what to get/avoid?
Thanks,
Carl
Old Feb 18, 2011 | 03:33 PM
t150vej's Avatar
t150vej
any suggestions on what to get/avoid? Carl
The link posted was apparently for a photo and I can't get it to come up but anyway...
Be careful - you will likely need one suitable for a 2-cycle engine as the stock or any dual fire ignition fires every revolution which will double the reading on a tach designed for a 4-cycle engine. If you're using a module that is single fire, then any automotive version should work.
OK, I stripped the link down to the item number and found it... that will work, but you will need to "half" the RPM reading since it doesn't have a switch for 2/4-cycle. That is fine for testing and my explaination was in case you were going for a mounted-going down the road type tach
Old Feb 19, 2011 | 02:15 PM
carlgrover's Avatar
carlgrover
Sorry the link was such a problem. I'm running the stock RKC ignition. Is that a "wasted spark" system?
Thanks for the help.
chris_lacey
Feb 21, 2016 09:56 AM
Mrrick
Shovelhead
Aug 24, 2009 12:26 PM
solitaryman54
Ironhead
Apr 2, 2007 01:54 AM
rotorwing70
Dec 29, 2006 03:55 AM
rotorwing70
Dec 28, 2006 08:02 PM
