camshafts
Old Mar 6, 2011 | 11:37 AM
miacycles's Avatar
miacycles
Gsxrboy, of course a Woods cam would be noisy-- They need to be put in a Harley Not a GSXR!!!!--- LOL But seriously you can get the noise down some but it takes work and a lot of clearance checking, you need to make sure that all the "slop" is out of the valve train.
Old Mar 6, 2011 | 01:32 PM
1997bagger's Avatar
1997bagger
I would still give $75 for it, the rust would give it more lift and make it a custom grind. See if you can find it!
Old Mar 6, 2011 | 04:32 PM
gsxrboy96's Avatar
gsxrboy96
i mean, i eyed it up the best i could lmao, in all fairness, it may have just been a culture shock when i got off a very quiet, tight japanese bike, and threw my leg over a air cooled big twin, i mean, lets be real, if a metric bike rattles like that, it isnt making it home, and even with that said, my twins i have now, dont rattle quite like that, but my inexperience could have played a role in the noise of the cam, but i can assure you the end play was set correctly lol,
and 97 bagger, your more than welcome to swing by the house, we have a nice green pond that it rest at the bottom of, hell, u come get it, you can have it ! lol and it even has a red gear pressed on ......
Old Mar 6, 2011 | 06:23 PM
blair's Avatar
blair
I run an Andrews EV27 and single fire ignition and it a screamer !!!!
Old Mar 11, 2011 | 09:59 AM
clove07's Avatar
clove07
Default comp cam 569 lift
I found a brand new comp cam 569 lift. Cheap does anyone have any input in this cam or brand?
Old Mar 11, 2011 | 10:29 AM
98 FLHX's Avatar
98 FLHX
V-Thunder is made by Comp Cams...not sure if that is what you mean.
If so, I feel the V-Thunder is one of the best cams out there. I run one now, and have in previous bikes with excellent results.
They are whisper quiet, and produce very good power. I've ran the EVL 3030, and I have the EVL 3040 in my current bike.
As far as .569" lift.. the EVL-5005 cam has the following specs:
Lift- .569"
Duration- 236/236
Timing- 18/38 42/14
It's one of their Extreme Energy cams.
Here's a link....
http://www.compperformancegroupstore...Code=EVOXTREME
Tony_N
EVO
17
Feb 1, 2016 06:08 AM
hd_rolling
Exhaust System Topics
Aug 29, 2012 12:51 PM
TO34
Apr 27, 2011 11:42 PM
Nexus9
Feb 22, 2011 07:50 PM
eds06roadglide
Nov 9, 2010 09:21 PM
