New and not charging
Here's where I'm at, a month back when I was doing all the upgrades I started the bike ( it is always on the battery tender to keep battery up ) when I started bike it whirreled over really well and with my volt meter across battery I got 12 volts and thought it was charging so I went onward with other upgrades. Today I finally got bike out, was dying to try the tranny rebuild and new clutch, that part went well.
Went for cruise out to my buddies and when I went to leave click click no go. We put boost charger on bike and started ok, we put volt meter at starter stud and ground and got 11.6, by the time I got home got 11 volts across starter stud and ground. I have the battery back on battery tender right now so I can start and test with you guys directions.
I've read all about dreaded click and NGHawgs thread of Poor Bertha https://www.hdforums.com/forum/evo-c...-problems.html, very nicely documented and will also refer to it if needed.
I'm not sure if all the troubleshooting described in Poor Bertha would be the same as my situation because mine is 3 phrase. My system has 3 wires coming from stator to the regulator.
Please help me out here guys, where should I start.
PS I know how to use my voltmeter for checking volts and ohms but I admit I don't really understand the purpose of the different value settings.
Thanks
thanks
