cold exhaust
Old Apr 10, 2011 | 01:48 PM
gnafin's Avatar
gnafin
Default cold exhaust
hi, i was starting my 1984 FLHTC and i put my hand by the exhaust and found that the right side exhaust is hotter then the left side....is this normal?
Old Apr 10, 2011 | 03:25 PM
Spanners39's Avatar
Spanners39
Depends what you mean by hotter? If its only running on one cylinder one will be way hotter.
Old Apr 10, 2011 | 05:13 PM
gnafin's Avatar
gnafin
ya, if i put a timeing light on the back cylinder it flashes but then it cuts out....Hmmm bad coil?
Old Apr 10, 2011 | 05:58 PM
95yj's Avatar
95yj
Do you have a stock ignition? If so, both the front and rear cylinder always fire at the same time with one spark wasted. Getting spark to just one cylinder is probably a plug wire or plug.
Old Apr 10, 2011 | 08:15 PM
#1rocketman's Avatar
#1rocketman
Plus,if you've got stock exhaust on it,you won't have much coming outa the left exhaust anyway.
thirdeye
May 12, 2021 08:43 PM
wseyler
EVO
Jul 22, 2018 02:26 PM
kevinrdc
May 18, 2017 10:53 AM
trboatri
Engine Mechanical Topics
Aug 9, 2010 06:02 AM
Thermoman
Exhaust System Topics
Mar 18, 2009 09:52 AM
