Sticking Valve on A Sporty
And can hear it just firing on one, until it warms up, then it usually takes care of itself, and runs fine.
Anyone else ever have this problem?? And a good solution??
Thanks!
Randy
Have you checked to make sure that the rear cylinder is getting spark? It's much more likely that there's an issue with the coil (or somewhere else in the ignition circuit) that's preventing the rear cylinder from firing until it's warmed up.
And I recently did a compression check on both cylinders, and they were both fairly equal.
But he bike was warmed up when I did the test.
Also, again, a valve cannot stick closed. If it did, it would break something in the valvetrain. For a valve to stick closed, a rocker arm would have to snap, a pushrod would have to break, or the cam would have to fail somehow. None of those would get better when the engine warmed up.
Even if the hydraulic lifter collapsed, that would not be enough for the valve to stick closed. A collapsed lifter would also clatter very noticeably until it pumped up.
The valve could potentially stick partially open if something got stuck on the valve seat, but that's not what you're talking about.
You need to check for spark, and check cold compression values. Remember, when checking compression numbers, you need to have the throttle wide open.
