problem with my brothers 98 1200
Old May 26, 2014 | 09:41 AM
junglejoe's Avatar
junglejoe
Default problem with my brothers 98 1200
Was out riding yesterday with my brother, I was riding his bike so I can check out mine, looking and listening to it, but his was running PERFECT! We pull into a gas station, sit for about 30 minutes, he went to leave on his fired it up, running on one cyl. popping out of the exhaust. Changed the coil, same thing. Changed the plugs, same thing. Pulled the plugs, spark was very weak looking to me. Do those have a cam sensor? Any suggestions??
Old May 26, 2014 | 01:56 PM
Dr.Hess's Avatar
Dr.Hess
Is there compression on the back plug? Use your built in compression tester (thumb). Pull plugs, put thumb over spark plug hole. Crank motor. Compression pushes thumb off hole. Same on front and back?
Old May 26, 2014 | 02:57 PM
junglejoe's Avatar
junglejoe
Welp...compression on the front is 170psi the rear is 20 psi! Something came loose!!
Old May 26, 2014 | 05:20 PM
johnjzjz's Avatar
johnjzjz
chances are its an exhaust valve hit the piston - valve guide seal leaking into the exhaust guides has clogged the botton and it turns into glue with carbon rocks and that sticks the valve in the open location - badda bing the valve is done - < it gets wacked
Old May 26, 2014 | 06:09 PM
Dr.Hess's Avatar
Dr.Hess
Exact same thing (gas station, 30 minutes, rear cylinder dropped...) happened to me. Valve guide dropped out of the head. Valve was OK.
Old May 26, 2014 | 06:14 PM
junglejoe's Avatar
junglejoe
WTH would cause that!? I personally was riding it, pulled into the parking lot, it was running like a sewing machine! He went to start it, popping backfiring like hell!! There is NO noises or **** rattling around in that head that I can hear either..going to take it apart soon!
Old May 26, 2014 | 06:22 PM
Dr.Hess's Avatar
Dr.Hess
Well in my case, the exhaust crossover pipe was leaking, when we stopped, cold air sucked in and hit the valve guide, which shrunk it without shrinking the head. Hit the starter and the valve and guide dropped out of the head, 850 miles from home, leading to:
Old May 26, 2014 | 06:52 PM
junglejoe's Avatar
junglejoe
Well, guess we'll tear it apart and see wuts going on with it..THANKS!
Old May 26, 2014 | 08:01 PM
junglejoe's Avatar
junglejoe
Well,.... GOOD NEWS!!! I decided to take the breather off, get me a squirt bottle(Windex bottle) idled it up, squirted some water in the ole carb, I mean A LOT! Then got me a cap full of trans fluid,took the sparkplug out of the rear, dumped it in the head. Started it up, squirted the trans fluid into the intake....BAMM! Running like new money again!!
thirdeye
May 12, 2021 08:43 PM
laserman2431
Sep 25, 2012 04:55 PM
Joe's FLH
Welcome Area Only
Aug 22, 2011 08:45 PM
imbthree
Exhaust System Topics
11
Oct 25, 2009 09:38 PM
Razorback Rob
Dec 31, 2008 09:19 AM
