Electric Draw?
Old May 12, 2021 | 05:46 PM
LordSargon's Avatar
LordSargon
Default Electric Draw?
What's up folks, me again...
So this morning (45°F) my sportster wouldn't start and presented symptoms of a weak battery. It seems to do this on every cold morning.
This afternoon, I tried to start it again, and it started first shot no problem. (65°F) This battery is a month old.
Now what I noticed, on the speedometer, the arrow doesn't seem to be settling even when I pull the battery fuse. It drops when I shut the engine off, then goes back up. Can this indicate a loose draw somewhere? I'm honestly completely stumped. Electrics are my weakness, so any guidence on what to do next would be amazing.
Old May 12, 2021 | 06:36 PM
CoolBreeze3646's Avatar
CoolBreeze3646
1st Remove the battery and bench charge it, then take it and get it load tested to ensure it has the appropriate Cold Cranking Amps (CCA). Even new batteries can be faulty. Once tested and if okay follow the procedures to test for power drain.
I would not worry about other stuff until I was sure the battery is good.
Old May 12, 2021 | 08:07 PM
im's Avatar
im
OK,
I will take a guess that you have a sportster of an unknown engine size and year.
By chance do you have a lithium battery?
Old May 12, 2021 | 09:29 PM
LordSargon's Avatar
LordSargon
Originally Posted by im
OK,
Apologizes, forgot to list that. 2008 Nightster, has an AGM battery.
Old May 13, 2021 | 08:06 AM
Gary1's Avatar
Gary1
Get you a cheap volt/ Amp meter and remove the battery cable and measure the draw if any. A few milliamps would be normal.
Old May 13, 2021 | 08:54 AM
John Harper's Avatar
John Harper
With EFI you will have some power draw even when bike is turned off.
John
Old May 13, 2021 | 09:06 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
About 120 or so milliamp draw. If you have an alarm, close to 40 more as attach battery in line with it set or wire leads positioned for amp draw.
That trims off in about 30 seconds to 120 as the alarm goes to sleep mode.
A new battery really needs charged when brand new on a bike unless you run it 4 hours or so.
A good battery will start a bike a few months without running. Never jump a bike except in an emergency.
Take that volt/amp/OHM meter and just hook it to your maintenance leads on DC volts. Crank it. If it drops below 9.7, battery is dead or bad. 12.7 is full charge. 12.3 is dead battery.
Old May 13, 2021 | 09:08 AM
im's Avatar
im
You have a 2008 Nightster of unknown mileage, unknown ownership history, unknown modifications from stock and unknown condition.
It is unknown if motor has been altered in any way.
We know that bike has a 1 month old AGM battery of unknown brand.
Is it the correct battery? Same cranking amps as stock?
Have battery cable connections been reviewed? all FOUR ends?
For example: Some batteries require a provided spacer at terminals in order for battery cable to sit correctly at posts.
Sometimes the other ends of battery cables are loose. Check the FOUR ends.
Has battery been removed and taken to a shop for a load test?
Just because a battery is new does not mean that it is not defective.
Have you tested charging system with a simple digital voltage meter connected to battery post? voltage at rest, Key ON, Cranking, at idle and above idle?
If all this tests out then a simple parasitic drain test can be performed with a cheap digital voltage meter.
gargoyle13
Mar 15, 2021 07:48 AM
PierreG
Jun 29, 2018 11:02 AM
GLS45
Nov 8, 2016 06:35 PM
Titan307
Oct 17, 2013 09:30 PM
avgnick
Dec 29, 2008 03:08 PM
