Evo engine case sealer?
Old Apr 14, 2011 | 03:43 PM
Doug S's Avatar
Doug S
I've often wondered the same thing, My 94 has a thin bead, it's a little tougher than silicone but it's not hard either and it does have some stretch. I have oem hoses and clamps and I've had the bike since 20k and the first owner did not admitt to bottom end work. Top end has had work, it runs strong, smooth and dry. I had a 99 and it did not have any visable sealant.
D
Old Apr 14, 2011 | 05:37 PM
miacycles's Avatar
miacycles
You need to use Permatex Ultra grey Rigid High-Torque RTV Silicone Item #82194. You need to drill a .035" hole in the end of the applicator, and run one bead all the way around on one side only 1/3 the way in from the outer edge and around all the bolt holes. It is really hard to squeeze the silicone through this little hole, so have patience!!!!Allow it to dry all day and overnight. The next AM inspect it and carefully remove any that squeezed inside with a pick and some grease to pick up any pieces. Hope this helps.
Old Apr 14, 2011 | 05:40 PM
miacycles's Avatar
miacycles
Originally Posted by JohndeereA
It is soft and I can pull it like a rubber band, the oil hose clamps are the factory
crimp style.
I am trying to determine what would cause the nasty viabration at about 1,800 to
2,000 and comes in again at 2,800 RPM,
it is a high frequency vibe that actualy hurts (not a typical HD shake).
Have you done a compression and leak down test yet???? How is that primary chain, a loose or bad chain will cause some funky vibrations as will a loose clutch or compensator sprocket. Hope this helps.
Old Apr 14, 2011 | 09:38 PM
JohndeereA's Avatar
JohndeereA
SE-3 Cam, milled heads, SE air cleaner,
I did check compression, it was 175# even on both cylinders engine cold.
The primary chain was at 3/4 " cold.
The front mount had the threads stripped out on the bottom hole (alum)
So I will replace it this week end, the mount looked good, I put a lomger 3/8
bolt in it and rode it but no change.
The timing was so far advanced the dot was out of sight, I had to retard
it two (large lines) on the plate but it did not make any difference.
I listened with a scope on the primary but did not hear any strange noises
other than a light rumble sound (not loud) by the clutch.
Thanks
Old Apr 15, 2011 | 09:14 AM
stevelonewolf's Avatar
stevelonewolf
Permatex Moto seal(grey).
machinehed
EVO
Mar 23, 2014 09:15 AM
FXWGG
Jun 7, 2009 04:21 PM
AK97fxdwg
Feb 10, 2009 06:46 AM
harleydude68
Apr 13, 2008 03:27 PM
Tucker99
Mar 24, 2008 11:50 AM
