starting problem
Old Apr 22, 2011 | 09:00 AM
pd76's Avatar
pd76
Default starting problem
1990 electraglide classic would not start has a new starter relay, locted a breaker near the relay and touched the post together and then the bike started.Does it sound like this breaker is the culprit.
Old Apr 22, 2011 | 10:58 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
That breaker is the main. Everything else should have been dead also until you jumped it. Did you notice this?
Old Apr 22, 2011 | 12:24 PM
pd76's Avatar
pd76
+everything else was on , lights horn radio, you could hear the stater relay clicking and then i jump the breaker and it started
Old Apr 22, 2011 | 04:38 PM
Spanners39's Avatar
Spanners39
Bearing mind that a bike that old may have some "alternative wiring solutions" present I would replace the breaker and go from there...will probably cure it.
Often with older bikes (especially FXRs it seems) what should happen and what actually works may be two different things.
Old Apr 22, 2011 | 06:30 PM
Jim Kraft's Avatar
Jim Kraft
All the lights and stuff would work until you hit the starter button, and then the load from the starter would create a high resistance at the breaker to keep it from starting. Changing out the breaker should fix it. The key word here is 'Fix". Let us know.
Oops! I should have said the key word is "should".
Old Apr 23, 2011 | 04:57 AM
Spanners39's Avatar
Spanners39
"Should" yes...that one little word has caused so much havoc when repairing bikes :-)
Old Apr 23, 2011 | 07:16 AM
V-Twins & Bowties
Take and disconnect, clean ALL the connections and terminals, reconnect and go from there.
Old Apr 23, 2011 | 01:04 PM
RidemyEVO's Avatar
RidemyEVO
Don't forget the dielectric grease.
tphillips
Jan 5, 2017 02:45 PM
jack2sam
Electrical/Lighting/Alarm
Jun 1, 2012 06:32 AM
Booey424
May 21, 2011 10:54 PM
Failz
Jul 7, 2009 03:35 PM
