Primary Plug Leak After Teflon Tape
Old Apr 27, 2011 | 08:17 AM
carlgrover's Avatar
carlgrover
Originally Posted by Tom84FXST
The primary plug should be 1/2-20 thread...not pipe thread. It seals with a washer, Teflon tape is a waste of time...if it is leaking you need a new washer. If it has a pipe plug in it , you have problems.
I've got the same bike as the OP. I don't have a washer on mine. My plug also threads pretty deeply into the primary. Not leaking though.
Old Apr 27, 2011 | 07:07 PM
TurkeyRun's Avatar
TurkeyRun
FWIW, my 96 FLHR had a "leak from the primary drain plug" as well. I ended up replacing the inner primary seals, still leaked. When I took a good look at the derby cover, it was warped. Replaced the "HD Logo" one with the funky gasket with a plain one from Drag Specialties, STILL leaking!
I ended up using a little gasket sealant around the derby gasket and now - dry as a bone.
Just sayin', if you changed the fluid, you might want to check that derby cover, its gasket, and maybe try a little goop on there and see what happens.
Old Apr 28, 2011 | 04:25 AM
96roadking's Avatar
96roadking
Mine is a pipe plug, 1/8" NPT. Very loose fit, teflon tape worked for mine.
Old Apr 28, 2011 | 07:15 AM
JosephH1's Avatar
JosephH1
Thanks everyone! This morning I went and picked up a can of industrial high pressure thread sealant. It is rated for petroleum so I think it will handle the low pressure environment of the primary. I will give it a shot Saturday and let you know how I fare.
Old Apr 28, 2011 | 09:12 AM
miacycles's Avatar
miacycles
The plug is pipe thread which is tapered. The problem a lot of riders have when they do their own maintenance is they tend to overtighten most pieces. Originally the plug is supposed to stick out 1/8". However when the plug is overtightened, because it tapers it stretches the hole out and can even crack the primary.. Try putting 4 or 5 wraps of a good teflon tape around the plug and just put it in snug. Remember it is not a head bolt. Hope this helps
BigFatHawg
May 10, 2010 06:18 AM
crazytrain69
Jul 12, 2009 07:22 AM
Frankster69
Sep 21, 2008 10:20 AM
rpmp3
Jan 20, 2008 10:12 PM
bancquo
25
Jan 24, 2006 02:11 PM
