front brake caliper problem
Old May 2, 2011 | 05:40 PM
JohnFlorida's Avatar
JohnFlorida
Default front brake caliper problem
97 heritage flstc- front caliper was making noise so I took it apart to clean. Looks like to piston seal has melted . There was a silicone looking material stuck to the pad where the piston hits. Piston isnt moving but it looks like the dust seal bulges out against the pad when I pull the brake lever. I think the piston has seized up. Would it be better to try a rebuild kit or just buy a new caliper? Anyone know of a good priced brake replacement? Goldline does rebuilds - anyone use them?
Old May 3, 2011 | 05:25 AM
Spanners39's Avatar
Spanners39
Get apart and rebuild if not a mess of corrosion.
Old May 3, 2011 | 08:20 AM
NutterFLH's Avatar
NutterFLH
Yes, rebuild it. If the caliper is not damaged it will work. If You have 2 calipers at front then rebuild both at the same time.
smithbrl
Aug 4, 2020 07:32 AM
Napalm Dog
Feb 24, 2015 06:51 AM
Mpderksen
Jul 8, 2014 07:57 PM
kk6pg
Jul 10, 2012 05:32 PM
dg7080
May 13, 2009 04:09 PM
