evo oil pressure
Old May 6, 2011 | 07:12 PM
evofloyd's Avatar
evofloyd
Default evo oil pressure
When my lifters went out it also took out the oil pump. So I went with the S&S oil pump. Sence then the oil pressure 60# cold , 20# hot at an idle. Cold she would push oil out the push rod tubs if any more rpms then an idle. Called S&S tech and they told to mill out 50 thouands out of the pressure release valve cap to lessen the spring tension. Any way what a pain its been, but now I can start it cold {40#} Wish they would put that in their insulation instructions of the pump for the evo.
Old May 7, 2011 | 02:39 AM
Spanners39's Avatar
Spanners39
That kinda thing just sucks!!! Its like SE not telling you you have to open out the holes on the rocker platform so the valve springs don't bind when you fit SE heads....
Old May 7, 2011 | 05:26 AM
Tom84FXST's Avatar
Tom84FXST
That kind oil pressure on an EVO is unusual...I am sure S & S doesn't get many calls complaining of too much oil pressure. Mine is around 50# cold and maybe 2# at idle when hot with the S & S pump.
Charlie Bone
EVO
39
Jan 29, 2016 03:58 PM
shovelhead FXEF
Shovelhead
Apr 3, 2013 08:21 PM
Plow64
EVO
Sep 26, 2010 12:43 PM
Knucklehead1941
Shovelhead
21
Jun 15, 2008 08:21 PM
seitzler@svinet.com
Oil Archive (no new posts)
Nov 9, 2007 06:23 PM
