Brake Light Switch for Softail
Old May 19, 2011 | 05:13 PM
cwhite6's Avatar
cwhite6
Default Brake Light Switch for Softail
The FSM is mute on where the rear brake light switch mounts on a 1998 FLST. I am assuming it is a tee in the brake line that the switch threads into. It doesn't show mounting position, bracket or anything. Can someone with a FL softail in the mid to late 90's take a picture of the mounting for me and post it up? It would be greatly appreciated. Thanks.
Old May 20, 2011 | 03:36 AM
Spanners39's Avatar
Spanners39
Should be in a bracket on the steel (rigid) brakeline between the caliper and the transition to the rubber hose.
Old May 20, 2011 | 10:54 PM
cwhite6's Avatar
cwhite6
Anyone have a pic of this?
Old May 21, 2011 | 12:53 AM
Spanners39's Avatar
Spanners39
This is off a 98 Dyna, the softie is very similar.
Old May 21, 2011 | 03:37 AM
piperbob's Avatar
piperbob
Just follow the line back from the master cylinder.
Bob
97 Heritage
Old May 22, 2011 | 09:06 AM
cwhite6's Avatar
cwhite6
Bob
97 Heritage
I have nothing to follow. I am building this bike from the ground up.
cwhite6's Avatar
cwhite6
Thanks alot. That helps.
Old May 22, 2011 | 09:45 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I have a '95 FLSTC and there is a small bracket that bolts to the transmision case (lower rear) that attaches the bracket that holds the brakelight switch. I can't figgure out how to post a picture here but if you send me an e-mail address I can send it to you that way.
Old May 22, 2011 | 12:54 PM
texashillcountry
Dirt don't hurt
https://picasaweb.google.com/214mike...98657896549682
Not sure if this will work but maybe
Old May 22, 2011 | 02:22 PM
piperbob's Avatar
piperbob
Go here- http://www.goodridge.net/webapp/wcs/...1_32019_retail
or get the stock stuff from the dealer.
Bob
97 Heritage
