CV carb trouble
Old May 22, 2011 | 10:17 PM
ladman0311's Avatar
ladman0311
Default CV carb trouble
Hello All,
I just got done doing a huge engine build on my 93 fatboy evo. i changed the compression to 10:2:1. i had to put compression releases on the heads so i will start eaiser. the only down fall is some times the compression will knock the carb off the bike? i have a new rubber bezzil that goes on the end of the manifold that holds the carb on, but it seems like it is too big and is assisting in the falling off of the carb.
is there a bracket i can buy that will hold the carb to the bike better? how can i stop this from happening?
Old May 23, 2011 | 04:42 AM
Spanners39's Avatar
Spanners39
Nah mate, compression isn't doing that, the carby should be held on by the back plate and the breathers...the Ironhead boys are masters at making brackets to hold the CV in but in your case I think you have bits missing from the aircleaner set up...if your set up isn't attached to the heads then its time to get the drill and some steel strip out.
Old May 23, 2011 | 04:57 PM
omgtkk's Avatar
omgtkk
Yeah, what Spanner said. Your carb should be held in place by an air cleaner backing plate that mounts to the throat of the carb with 3 studs and then mounts to the breather bolts on the heads. If your carb is just stuck onto the manifold with the compliance fitting, well, something ain't right. Who did the rebuild, you or a mechanic?
Old May 23, 2011 | 05:25 PM
ladman0311's Avatar
ladman0311
I did the rebuild last year I replaced the stock breather assembly with a different one and I did not have a problem I guess ill have to machine some kind of a plate yo hold it on
Old May 23, 2011 | 05:27 PM
ladman0311's Avatar
ladman0311
I also bought the bike used about 4 years ago and I don't recall the Carb being held on by the breather assembly
Old May 23, 2011 | 07:11 PM
Spanners39's Avatar
Spanners39
Try using a genuine H-D manifold rubber but it will fall out if its not attached.
Old May 24, 2011 | 12:44 PM
ladman0311's Avatar
ladman0311
I found the bracket online that should have been on the bike to begin with. I fabed up my own that works great. Thanks for the help guus
homiegfunk53
Carburetor Related
Aug 29, 2013 03:49 AM
Stan in Birmingham ala
Carburetor Related
Aug 28, 2013 04:16 PM
XMXER
Mar 28, 2012 09:10 PM
58Panman
Carburetor Related
Aug 19, 2011 11:39 AM
stone_rider420
Apr 14, 2007 11:03 AM
