Super E rich intermediate problem
Old May 31, 2011 | 03:21 PM
jokenroll's Avatar
jokenroll
Question Super E rich intermediate problem
Gentlemen, I have a weird problem with my Super E - it seems that it is running rich, judging by the screw setting.
When it had a stock jet - 29.5, I had to adjust it only 3/4 turns out (regular by-the-ear procedure). I checked the float level, needle properly closing, needle being stuck, and everything seems to be ok.
I also cleaned the enricher (plunger and the well, making sure it's not leaking through there) - nothing helped.
So I've installed the smallest jet - 28. That resulted in the screw being just slightly less (!) than a turn out.
My main jet is 72, and judging by full throttle behavior, it appears to be correct.
What else could be wrong?
Old May 31, 2011 | 04:16 PM
Spanners39's Avatar
Spanners39
That would be right, out is richer and a smaller jet would require the screw to be turned out more to get the right air/fuel ratio to idle properly.
Full instructions here http://www.nightrider.com/biketech/d.../super_e_g.pdf
Old May 31, 2011 | 07:46 PM
pjb's Avatar
pjb
you can get the detailed instructions on S&S's website. They are very good.
Old May 31, 2011 | 08:37 PM
2006FLST's Avatar
2006FLST
If you are about a turn out and running a 28 on a stock bike then I would say you are good. I had an S&S on my last stock evo and that was about where I ended up. S&S calls for 1-13/4 turns (or something like that). Also get a good plug reading as well.
Oh and everyone is right about the S&S instructions they are very detailed and good.
Old May 31, 2011 | 11:34 PM
Bama91's Avatar
Bama91
The way I checked my S&S on my Ironhead, I put a pack of plugs in my tool bag and a plug socket. Run it down the road at low throttle and shut it off. (don't slow down and stop, shut it off while traveling) and pull the plugs. Check them out and adjust the setting, put in new plugs and repeat. You can't get it right at idle and at full throttle you are checking the main. If you idle down and stop before you shut it off you will get a false plug read. Hope this helps. It's time consuming but it worked for me.
Old Jun 1, 2011 | 05:32 AM
topfuel7's Avatar
topfuel7
Not sure what Mods you have but a 72 is kind of big.
Old Jun 1, 2011 | 06:12 AM
prodrag1320's Avatar
prodrag1320
check the little blue O ring on the acc. pump nozzle,if its damaged,fuel will come around the sides of the nozzle,VERY common prob on S&S shorty carbs
Old Jun 1, 2011 | 09:22 AM
jokenroll's Avatar
jokenroll
Thank you, gentlemen!
Well, I was actually going by S&S instructions, but that's what they say - if it ends up less than 1 1/4 turn, your jet is too big.
Interesting point on the O ring - thanx prodrag! I checked it - it's not really broken, but rather slightly squashed - could that be it?
Old Jun 1, 2011 | 06:40 PM
topfuel7's Avatar
topfuel7
I just assumed you have been looking at the plugs. It is a real good way to tell what the engine needs. Every bike is different and requires different tuning but mine has several mods and I use a 28 intermediate and a 70 main. A 68 main does better for around town or normal cruisin but it leans out a little much on the top end if I run it hard so I run the 70 for a good in between. The 72 made mine a little to rich and it feels a slight bit more slugish with it.
Old Jun 1, 2011 | 09:28 PM
Dr.Hess's Avatar
Dr.Hess
I'm running a 265 intermediate and a 64 main. My bike runs great, but my gas mileage isn't all that good. At least at 80 on the interstate, but that's probably why, given the barn door aerodynamics.
