oil pump issues?
Old Jul 3, 2011 | 03:12 PM
dmh's Avatar
dmh
6th Gear
tomo morning ill be waiting at the harley shop first thing when they open, ill order my books and also buy a sending unit, heard ther are fairly cheap, ive been told that is a common problem with the oil light? and i pulled the out oil line on the oil cooler and it was flowing out very steadily.
Old Jul 3, 2011 | 05:33 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The late `84 through `89 clutches are the same, the first of the diaphragm spring clutches.
The `84-`86 clutch throwout mechanism is different from the later models, the cable is connected to an arm outside the transmission case, which is connected to a finger inside the case, on the right side of the transmission.
Sometimes the finger inside the case breaks...
The adjustment method for this model clutch is the same as later evo type clutches, a locknut and the threaded rod, but unlike the later clutches, there is also an adjustment for the diaphragm spring, this is accomplished by installing the pressure plate in different positions.
No special tools needed to disassemble this model clutch, however, if you must remove the clutch hub from the mainshaft, you will need a puller.
Before you condemn the clutch, be sure it is adjusted properly, and that the cable, throwout mechanism and pushrod are all in proper working order.
Old Jul 3, 2011 | 08:02 PM
dmh's Avatar
dmh
6th Gear
hey i appreciate it! tomo ill check the finger your talking about
jclax01
Milwaukee Eight (M8)
27
Nov 24, 2021 09:10 PM
thumbbuster
Oil Archive (no new posts)
Jan 1, 2019 05:51 PM
ronnie41653
Oct 23, 2013 08:48 AM
peted172
Shovelhead
May 19, 2010 05:26 AM
Bobsportster
Exhaust System Topics
Apr 26, 2007 02:36 PM
