Pulled my Spark Plugs and......
Old Jul 9, 2011 | 02:29 PM
mdanehart's Avatar
mdanehart
Default Pulled my Spark Plugs and......
Just for the heck of it I pulled my plugs on my 93 softail and they were covered in with white ash?
The bike has 10:5 pistons, Woods W6H cam, Python 2:1, Crane Hi-4 with the advance slope setting at 3, heads modified, Mikuni HSR-42 with a 96 jet needle and 165 main. Could I being running to lean? Bad fuel? The bike runs real strong with occasional detonation under extremely hard acceleration. I do use Lucas octane booster when the need arrives...Any input? Thanks in advance.
Old Jul 9, 2011 | 03:51 PM
miacycles's Avatar
miacycles
Some octane boosters leave a residue behind. What plugs are you runnuing??
Old Jul 9, 2011 | 04:24 PM
mdanehart's Avatar
mdanehart
The plugs are screamin eagle brand gaped at .40. The cheap version....lol
Old Jul 11, 2011 | 05:00 PM
miacycles's Avatar
miacycles
When you bought them are they for the stock bike, if so you need to go one heat range colder for 10.5 compression. The stock plug will be too hot. Hope this helps.
Old Jul 11, 2011 | 07:14 PM
topfuel7's Avatar
topfuel7
I have similiar mods and I went through a few different brands and heat ranges until I got to the NGK BPR7ES. The BPR5ES is stock so the 7 is 2 steps colder and seem to work the best for me. Mine was so severe I was salting the plugs and timing or jetting would not completely cure it. Octane boost helped some but the 7's have stopped it completeley now.
Old Jul 11, 2011 | 07:51 PM
mdanehart's Avatar
mdanehart
Thanks for the information. I assumed the octane booster was the contaminate! I will check into the plugs on Tuesday.
Last edited by mdanehart; Jul 13, 2011 at 11:32 AM. Reason: my jets are not important to his application.
Old Jul 13, 2011 | 11:33 AM
mdanehart's Avatar
mdanehart
Located the last 2 NGK at my local NAPA....
Old Jul 13, 2011 | 01:46 PM
Kabear's Avatar
Kabear
Sparkplugs.com is the place to be.
tryoung71
Jan 24, 2018 11:42 AM
BlackNBlue
Sep 12, 2013 07:42 AM
northeastconfederate
Exhaust System Topics
11
Jan 7, 2012 06:41 AM
Mike Kautzman
Dec 25, 2010 12:00 PM
bob53
Sep 27, 2006 05:23 PM
