No power to switch
Old Jul 14, 2011 | 03:54 AM
teamstersteward's Avatar
teamstersteward
Originally Posted by MJ
I assume that he has also checked this. Every so often I have to retighten my positive battery cable. The vibration continues to vibrate it loose. I have installed external star lock washers and it seems to help, but still tends to loosen up. I have owned the bike for 8 1/2 years and have had to do this since I have owned it. Always seems to show up when I decide at the last minute to ride with the Florida Crew. Again! Just my experience.
ditto on the loose cable (I do not bolt my seat on anymore"lazy")
had a similar starting issue on the fatty turned out one of my breaker had some rust/corrosion so I clean it up and no more issue
good luck I hope you find an easy solution
Old Jul 14, 2011 | 04:36 AM
piperbob's Avatar
piperbob
You checked both sides of breaker to ground?
Bob
97 Heritage
Old Jul 14, 2011 | 06:28 AM
JohnFlorida's Avatar
JohnFlorida
Loose positive it was. Figured it out last night. Take seat off and while going thru system the cable would reseat then put seat back on and sit down to start it would pull it loose just enough. Positive is a side mount with just enough cable. Wouldnt Harley think to use a longer cable and top mount so the seat would hold it in place . I cant believe I spent 5 hours tracking down a loose battery connection.
Old Jul 14, 2011 | 10:51 AM
MJ's Avatar
MJ
Glad you got it fixed John! Now jump over to the Florida Crew Section and introduce yourself. You need to join us on a ride sometime and better yet our annual get together is in Ocala the second week of Nov.
Old Jul 14, 2011 | 05:28 PM
scoteh's Avatar
scoteh
Good to hear that's all it was. Electrical gremlins are evil!
Old Jul 15, 2011 | 07:01 AM
Sam07's Avatar
Sam07
Every oil change I make it a point to check and clean(if needed) my battery cables. I have the L brackets on my battery and found the positive loosen up twice too. Its an old habit from owning 3 Buells.
Old Jul 15, 2011 | 09:43 AM
BB4xl's Avatar
BB4xl
Like MJ said these do help keep the battery bolts tight.
Old Jul 19, 2011 | 03:24 PM
JohnFlorida
Put star washers on and backed it up with zip ties
PoincianaRoadKing
Apr 21, 2020 02:13 PM
Tris S
General Topics/Tech Tips
May 15, 2019 11:06 AM
Kevlar
Electrical/Lighting/Alarm
Aug 19, 2016 12:00 PM
Mal74
Mar 23, 2011 09:30 PM
THABULL
Sep 15, 2008 05:54 PM
