banjo bolts
Old Jul 17, 2011 | 07:27 PM
roofer's Avatar
roofer
Default banjo bolts
Do any of you guys know if the banjo bolts on the evos and twinn cams are the same at the caliper and master cylinder Thanks
Old Jul 18, 2011 | 12:14 PM
95yj's Avatar
95yj
To the best of my knowledge, all the Evos and Twinkies use either 3/8-24 or 7/16-24 banjo bolts for the brakes. These are sometimes called 10mm and 12mm respectively even though the latter is actually 11.2mm.
The only exception to this is the 2004 - 2006 Sportsters which use true metric bolts on both the front and rear master cylinders and calipers. Most of these are 10mm-1.25 although some of the Sporsters have a12mmx1.5 on the front master cylinder. Fortunately, Harley went back to the SAE sizes in 2007 on the Sporties.
Old Jul 18, 2011 | 03:15 PM
TurkeyRun's Avatar
TurkeyRun
Wow! And that was in your head!?
(and I DO NOT mean that in a sarcastic kinda way)
Old Jul 18, 2011 | 03:49 PM
95yj's Avatar
95yj
LMAO. Well, most of it was and what wasn't took a walk to my spare/original parts drawers to verify. A month ago, I just bought the lines and cables for my new apes for my Heritage so the research was fresh in my mind.
As far as the Sportster, my gf has a 2004 Sportster which was the first year that things changed. (That's the year that the MoCo made a bunch of changes to the Sportster such as rubber mounted engine, different frame and on and on.) I put a pullback riser on her bars for her and had to change out the brake line. I picked one up at a shop while going through the States and was given the wrong size banjo bolts, so that's why the Sportster info is stuck in my head.
Old Jul 18, 2011 | 07:04 PM
roofer's Avatar
roofer
I knew someone on the evo forum would know thanks alot for the info
Old Jul 18, 2011 | 09:59 PM
Jim Kraft's Avatar
Jim Kraft
I can barely think of a part of an EVO era bike that has not been discussed on this forum. Outside of the Harley Manual, you guys are the greatest source of info around.
davidstipek
Apr 7, 2018 08:31 AM
rgm
Jan 23, 2013 09:58 PM
j88j
Oct 10, 2011 03:48 PM
dillon10
Mar 4, 2010 04:45 PM
stan928
Aug 29, 2009 12:22 PM
